Moroso oil pan>>>>???
Old Dec 17, 2006 | 04:05 PM
flipstar760's Avatar
Default Moroso oil pan>>>>???
check this out... im thinking about gettin a moroso oil pan. but the web site said it holds 5qt. off oil... i only but 3.7qt. in my car.... with that oil pan will i have to add more oil or what... what do you guys think?
Old Dec 17, 2006 | 04:11 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: Moroso oil pan>>>>??? (flipstar760)
why do you think you need that oil pan??
Old Dec 17, 2006 | 04:15 PM
Default Re: Moroso oil pan>>>>??? (Throwdown)
cause it said that it holds 5+ qt.
Old Dec 17, 2006 | 04:19 PM
rip94delsol's Avatar
well, the moroso oil pan is larger in size which would carry more oil!
if you are going n/a this would not be neccesary at all. The reason why people use it is because of the trap doors it incorporates inside for better oil availability around sharp turns, fast accelerating, or fast braking.
the other reason why people use moroso oil pans is so that they dont have to weld oil bungs for your turbo drain onto your oem pan. also some people mount oil temp sensors on their moroso oil pan aswell.
this is why you see two bungs on their 1 for turbo oil drain and the other for oil temp!
Old Dec 17, 2006 | 04:24 PM
Default Re: Moroso oil pan>>>>??? (rip94delsol)
im friend side the pans leaks... what do you know about that?
Old Dec 17, 2006 | 04:25 PM
Throwdown's Avatar
a lot of people like them cause they are baffled as well don't know what your intentions are but i've the only thing bad i read about was people losing OP taking sharpe turns autocrossing....
Old Dec 17, 2006 | 04:29 PM
the reason why im getting it is because im only paying $40 in the box unopened so i can still put 3.7qt. in my motor? what will the dipstick read?
Old Dec 17, 2006 | 04:42 PM
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipstar760 &raquo;</TD></TR><TR><TD CLASS="quote">the reason why im getting it is because im only paying $40 in the box unopened so i can still put 3.7qt. in my motor? what will the dipstick read?</TD></TR></TABLE>
Yes,you wil need to put 5 qts. in your stolen oil pan.The pan uses a longer oil pump pick up tube.You should be able to find a stolen one of those for $1.The dipstick reads full after you put 5 qts. of stolen oil in it.
Old Dec 17, 2006 | 04:43 PM
MasterKwan's Avatar
OMFG. Of course, you're going to have to add more oil. You have to add enough oil so it shows the oil at the same position on the dipstick. Whether that's 3.7 or 6 quarts. Add however much oil you need to to get the dipstick to read "full".
He's right about the pickup too. I'm thinking about paying FULL PRICE for a canton oil pan for my B16. Going to be running R-Comps and a turbo next year so, I need the trap doors, the extra oil AND the oil bungs.
Old Dec 17, 2006 | 04:48 PM
Throwdown's Avatar
Default Re: Moroso oil pan>>>>??? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">
Yes,you wil need to put 5 qts. in your stolen oil pan.The pan uses a longer oil pump pick up tube.You should be able to find a stolen one of those for $1.The dipstick reads full after you put 5 qts. of stolen oil in it.</TD></TR></TABLE>lol i don't care who you are thats funny
Old Dec 17, 2006 | 04:52 PM
1st of... you need to kick back with that stolen sh*t... im friend own me alot of money and he cant pay so thats how im getting it....
Old Dec 17, 2006 | 05:03 PM
do you know what model the pan is? some pans are made for specific engines! for sure you will need the moroso oil pick-up tube! i think they sell for around 40$.
also when you add oil start at 4qrts then check the oil if needed go in incements of 1/2 till you get the dipstick to read full!
Old Dec 17, 2006 | 05:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipstar760 &raquo;</TD></TR><TR><TD CLASS="quote"> Yes,you wil need to put 5 qts. in your stolen oil pan.The pan uses a longer oil pump pick up tube.You should be able to find a stolen one of those for $1.The dipstick reads full after you put 5 qts. of stolen oil in it.
1st of... you need to kick back with that stolen sh*t... im friend own me alot of money and he cant pay so thats how im getting it....</TD></TR></TABLE>
Then I guess its costing you a lot more than $40.
(760)doogie
Aug 7, 2008 02:58 PM
hondaboy4life
Sep 29, 2006 08:01 AM
BoostedH23a1
Oct 24, 2002 07:56 AM
GruvyTune
Nov 12, 2001 04:07 PM
