my rex is acting up, help me solve this problem
Old Dec 17, 2006 | 03:56 PM
haroldthefly91crx's Avatar
Default my rex is acting up, help me solve this problem
all of a sudden my, at idle, my tack. jumps from just under 500rpms to just over 1000rpms and when i rev it with lights on the lights brighten and when the rpms drop, the lights dim and sometimes (with lights on) my tac. loses power and i have no rpm reading untill i give it gas.
any ideas?
Old Dec 17, 2006 | 04:14 PM
turbo1.5's Avatar
Default Re: my rex is acting up, help me solve this problem (haroldthefly91crx)
Check to make sure your distributor is not loose (as in the three bolts that hold to the cylinder head) and check the thick wire at alternator to make sure that it's tight. The tach jumping around is a interuppted signal from the distributor, and if you have lights dimming and brightening the alternator is having issues.
Old Dec 17, 2006 | 04:18 PM
Default Re: my rex is acting up, help me solve this problem (turbo1.5)
i have a somewhat new alternator (it was in my old rex for about a year) and i checked all the connections and i made sure my distributer is tight. the car still starts most of the time and like i said everything tight, if my alternator is bad how can i test it at home?
Old Dec 17, 2006 | 04:25 PM
GoFastTshirts.com's Avatar
go to autozone they can check your altenator in your car for free and they can check your whole electrical system as well for free, def a great service.
Old Dec 17, 2006 | 05:07 PM
Rex-Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo1.5 &raquo;</TD></TR><TR><TD CLASS="quote"> ...........The tach jumping around is a interuppted signal from the distributor, and if you have lights dimming and brightening the alternator is having issues. </TD></TR></TABLE>
, I couldn't have said it better myself.
Old Dec 17, 2006 | 09:02 PM
JakeSpec's Avatar
check all your grounds under the hood especially the one from the trans bracket to the chassis
Old Dec 23, 2006 | 01:05 PM
Default Re: my rex is acting up, help me solve this problem (JakeSpec)
i replaced my alternator today and checked all the grounds i could find in the engine bay but im still having trouble
dakota1820
Honda Civic (2001 - 2005)
Apr 14, 2013 10:19 PM
dac123
Feb 18, 2008 07:02 AM
Sportyballade
Oct 22, 2006 05:57 PM
existanzcivicb20
Apr 21, 2006 11:12 AM
rudeman85
Mar 20, 2005 09:10 AM
