itegra disc swap
Old Dec 17, 2006 | 10:47 AM
Pr0ject93hb's Avatar
Default itegra disc swap
I have a 93 civic hb and i've been wanting to add disc brakes in the back. for a while i was thinking about just saving ans swapping to the ITR 4x114 or 5x114, but i just dont really have the money for the parts AND rims, so i'm just going to swap an integra over (since they're are tons in a junk yard).
so...my question is what exactly do i need. do i take the entire rear control arm and everything? or just the hub, rotar and caliper. i also need the break booster right? if anyone has some pics that would be cool too. thanks.
also does it have to be out of a DC2 or does a DA work?
Old Dec 17, 2006 | 10:53 AM
Default Re: itegra disc swap (Pr0ject93hb)
bump c'mon i needa know, i wanna swap asap. drums are acting up
Old Dec 17, 2006 | 10:58 AM
POE's Avatar
POE
there are a BANG load of threads on this .. Search is your friend.
And u need the Prop valve also, to have all the fluids proportioned out correctly to the back.
When you take the rear . Grab the Trailing Arm and all the brake copponets, and the e brake cable. If you can just grab the LCA's but if not, you will be ok. just makes it easier.
Old Dec 17, 2006 | 10:59 AM
Default Re: itegra disc swap (POE)
thanks. yeah search is my friend....just bein lazy lol.
Old Dec 17, 2006 | 11:01 AM
POE's Avatar
POE
The moderators will get down on ya for that..
Old Dec 17, 2006 | 11:52 AM
BlueIntegraBoy's Avatar
First off, you dont need a prop valve for a rear disc conversion. If you plan to do just the rear, you'll need everything from the trailing arm and back to make life a little easier. Which means everything on the trailing arm plus the ebrake cables and brake lines.
If Integras are abundant at the junkard as you say, I would suggest getting the fronts too. At this time, you will need a 4040 prop valve from a 90-93 Integra non-abs or 94-95 Integra RS. You will have need a larger master cylinder, which you can obtain from a 90-91 Civic EX.
8YourV8
May 31, 2007 10:02 AM
qat727
Dec 14, 2006 07:59 PM
sluger17
Mar 19, 2006 10:53 PM
SleeperEG-B
Nov 18, 2004 10:11 PM
sekone
11
Jul 26, 2002 11:18 AM
