stick problem or linkage?
Old Dec 15, 2006 | 04:37 PM
JDMBBL93's Avatar
Default stick problem or linkage?
i have a lsvtec bubble...wit a gsr tranny and stage 4 6puck clutch...ok heres the problem i think>>>>the stick for shiftin is very loose and has mad play...you can slap it around and i dont think this is normal...is it a problem wit the linkage or somehthin else??when i put it in 1st gear and let go it seems to go back into the neutral poision but its still the in the gear...drives perfect but the stick is too loose....lemme know some tips...thanks alot
Old Dec 15, 2006 | 05:17 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: stick problem or linkage? (JDMBBL93)
check the bolt's and bushings under the car by the shifter thats holds the back of the linkage
Old Dec 15, 2006 | 08:41 PM
my_slow_civic's Avatar
Default Re: stick problem or linkage? (Throwdown)
Also check the roll pin on the tranny side.
speedysohc
May 29, 2007 10:38 AM
Bartman201
Oct 3, 2005 11:09 AM
freshrex4g
Oct 25, 2004 05:47 PM
Lei Siew Long
Feb 6, 2004 05:36 AM
OldSchoolCrxSiR
Oct 14, 2002 10:58 AM
