Yet another IDLE + other problems
Old Dec 14, 2006 | 07:54 PM
lawlerlaw's Avatar
Default Yet another IDLE + other problems
Well, I searched it up on here and found many topics dealing with idle problems when the car warms up. But, in my case its the opposite. My car has a surging idle when i first start it up for about 5 minutes. After its warmed up the surging idle pretty much goes away? What could this be?
Also my temperature gauge fluctuates from just about overheating to normal within seconds. I pop the hood and the motor does not seem like it is overheating? Although sometimes it is glowing red by the cat? What could be causing the cat to get so hot? Could the cat being so hot make the temp gauge go up? I am begining to think that the cat is clogged(?), and it is in turn messing with the air flow or something? Somebody told me the cat or downpiple glowing red could be do to a fuel problem? I dont know im just guessing i need some help...
Thanks to all who reply
by the way car is a d16z6 motor with an CAI if that matters.
Modified by lawlerlaw at 5:17 AM 12/15/2006
Old Dec 14, 2006 | 11:46 PM
sexyrex's Avatar
Default Re: Yet another IDLE + other problems (lawlerlaw)
the cat is suppose to glow cherry hot, its doing its job...google its function.
as for the slight overheating and surging idle issue, check the coolant level and check for leaks.
Old Dec 14, 2006 | 11:47 PM
chrisw85's Avatar
if the cat is clogged it could get too hot...
Old Dec 14, 2006 | 11:51 PM
sexyrex's Avatar
if it got too hot, it'd melt his catalyst, thus throwing a code if obd2, and only way it'd melt would be excessive fuel, and if clogged ,his car would run roughly.
Old Dec 14, 2006 | 11:53 PM
sexyrex's Avatar
also the cat produces 100 degrees more heat
Old Dec 15, 2006 | 06:07 AM
lawlerlaw's Avatar
Default Re: (sexyrex)
no leaks and the coolant level is fine
Old Dec 15, 2006 | 06:41 AM
92ehatch's Avatar
Default Re: (lawlerlaw)
tighten the cap in the FITV for the cold idle problem see if that helps.
replace your thermostat for the overheating problem and see if that helps
replace the cat and see if that helps with the glowing red.
get back to us after
Old Dec 15, 2006 | 09:13 AM
lawlerlaw's Avatar
alright im gonna tighten the cap on the FITV to try and fix the idle problems when the car is cold. Its so embarassing especially with an exhaust so its so loud and everyone can hear it.
And where do I get a thermostat at? a dealer?
Old Dec 15, 2006 | 10:18 AM
Project_DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lawlerlaw &raquo;</TD></TR><TR><TD CLASS="quote">alright im gonna tighten the cap on the FITV to try and fix the idle problems when the car is cold. Its so embarassing especially with an exhaust so its so loud and everyone can hear it.
And where do I get a thermostat at? a dealer?</TD></TR></TABLE>Advanced auto/ Pepeboys/ Autozone
Old Dec 15, 2006 | 10:20 AM
92ehatch's Avatar
Default Re: Yet another IDLE + other problems (Project_DX)
go with honda oem. they arent expensive at all.
Old Dec 15, 2006 | 10:25 AM
93eg2james's Avatar
this sounds very ghetto, but its a test. take off you intake. there will be this little hole in the throttle body. put a peice of paper over it and see if it surges, then let me know
Old Dec 15, 2006 | 10:32 AM
92ehatch's Avatar
Default Re: (93eg2james)
wouldnt use paper, if you loose it and it goes inside the intake...whoopsies.
just cover it with your finger
Old Dec 15, 2006 | 12:05 PM
sexyrex's Avatar
get a bottle brush and intake cleaner and clean out your throttle body
Old Dec 15, 2006 | 12:18 PM
THC07's Avatar
do that thing where you plug it with your finger. like said above.
Then read this http://www.ef-honda.com/ben/Badidle.php
impr323
Sep 8, 2005 02:57 PM
Grnade
May 16, 2005 05:06 PM
EggEX2000
Apr 26, 2003 08:23 PM
Trac226
May 8, 2002 09:14 AM
