What's Causing this Engine Noise???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTECEG757 »</TD></TR><TR><TD CLASS="quote">you might need a valve adjustment</TD></TR></TABLE>
he definitely needs a valve adjustment. but the knocking in increments is weird. i've had some pretty loud tapping valves, but never knocking.
get an adjustment done and see what happens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleartouch33 »</TD></TR><TR><TD CLASS="quote">whats weird is when this clicking noise takes place, if i turn off the a/c, then it stops. if i keep the a/c off then it goes away. not sure if there is a direct connection??</TD></TR></TABLE>
when you say click you mean the increments, right? are you sure it's coming from the motor. you sure it's not the a/c compressor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
when you say click you mean the increments, right? are you sure it's coming from the motor. you sure it's not the a/c compressor.</TD></TR></TABLE>
I second that.
Find out where it's coming from, block, head, whatever. It might be an accessory like the AC comp.
Also, check the timing :-\.
EDIT:
Other possibilities (but not what I'd look into first) are fuel injectors and/or rotor/cap/plugs/wires.
I second that.
EDIT:
i think you guys are right about it being the a/c compressor. i didn't think of that until i figured the clicking stops when a/c is off. i will double check and get back to you guys. thanks for helping out. you guys are very helpful.
Jay
Jay
ej2civic
Oct 2, 2005 09:43 AM
