D15B swap
Old Dec 14, 2006 | 01:00 AM
adobospoon's Avatar
Default D15B swap
Just recently swapped in a d15b motor into my Vx hatch. Wanted to know if its safe running my motor with a vx ecu . I mean the ecu already has vtec but it is set at 2500. Will it affect the engine? One more thing will it make a major difference when I change my ecu to a p28 (Power wise) thanks
Old Dec 14, 2006 | 01:04 AM
Timmay's Avatar
Default Re: D15B swap (adobospoon)
you need the p28 for it to run right
Old Dec 14, 2006 | 01:08 AM
adobospoon's Avatar
Default Re: D15B swap (Timmay)
yeah i know. Just running it on the vx ecu just for temp. But is it bad to run on the vx ecu. I mean will it affect the engine.
Old Dec 14, 2006 | 01:57 AM
Timmay's Avatar
na it shouldnt .. but i would get the correct ecu asap
Old Dec 14, 2006 | 07:19 AM
adobospoon's Avatar
bump bump
Old Dec 14, 2006 | 07:48 AM
junior40er's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adobospoon &raquo;</TD></TR><TR><TD CLASS="quote"> One more thing will it make a major difference when I change my ecu to a p28 (Power wise) thanks</TD></TR></TABLE>
yes, dramatically. fuel mapping is WAY off.
Old Dec 14, 2006 | 10:09 AM
adobospoon's Avatar
Default Re: D15B swap (junior40er)
Alright thanks bro. Oh and one more thing. Im using my vx fuel rail. because the fuel line from the filter to the regulator would not fit on the d15b fuel rail. Is there a cheaper way of me getting a fuel line than rather spending 83 dollars for that one fuel line from honda.
Old Dec 14, 2006 | 10:31 AM
adobospoon's Avatar
bump bump
Old Dec 14, 2006 | 10:37 AM
instructor74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adobospoon &raquo;</TD></TR><TR><TD CLASS="quote">Alright thanks bro. Oh and one more thing. Im using my vx fuel rail. because the fuel line from the filter to the regulator would not fit on the d15b fuel rail. Is there a cheaper way of me getting a fuel line than rather spending 83 dollars for that one fuel line from honda.</TD></TR></TABLE>
Check a junk yard and strip one or look aftermarlet but I think it is a dealer only part
Old Dec 15, 2006 | 08:32 PM
adobospoon's Avatar
bump bump
Old Dec 15, 2006 | 08:33 PM
Syndacate's Avatar
Can you even use the VTEC-E VX ECU with regular VTEC?
They're nowhere near the same.
VTEC-E just has a regular camshaft...
I'm not sure the VTEC's hot swappable as the vibe everybody's giving off...
Also, your fuel maps are going to suck.
Bense would know this area well.
Old Dec 15, 2006 | 08:36 PM
Bense's Avatar
Ask schardbody, He knows this area more than I do. Good luck
Old Dec 15, 2006 | 10:13 PM
adobospoon's Avatar
Default Re: (Bense)
thanks bro. Really appreciate it
Old Dec 16, 2006 | 12:04 AM
SilverGT's Avatar
what happened to the vx motor? what is the exactl engine code? i have a ecu for a d15b8 [cx engine] with a complete motor too.
Old Dec 16, 2006 | 01:05 AM
adobospoon's Avatar
Default Re: (SilverGT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverGT &raquo;</TD></TR><TR><TD CLASS="quote">what happened to the vx motor? what is the exactl engine code? i have a ecu for a d15b8 [cx engine] with a complete motor too.</TD></TR></TABLE>
I swapped it out for a d15B. The engine code for the vx is a d15z1 and the motor i have now is a d15B. The ecu you have is not what im looking for.
integra_speed
Dec 18, 2008 06:19 PM
dturbo
Oct 17, 2005 08:00 PM
lemon_juice
May 6, 2005 11:41 AM
joepark2001
17
Mar 4, 2004 04:53 AM
