my car stops accelerating while moving HELP ASAP
Old Dec 13, 2006 | 07:25 AM
dthug's Avatar
Default my car stops accelerating while moving HELP ASAP
cars a 92 hatch with a 00 jdm b20b running a stock p75 ecu
while i'm giving it gas and holding the throttle it'll completly stop giving it gas. it'll move as if i wasn't giving it gas at all then if i still keep holding the gas pedal after a few its like jump right back as if i slammed on the gas
car has been doing has for the past 2 days and it happened outta no where. i just started my car up in the morning one day and it started to do this
as of yesterday i changed the dizzy cap, plugs, wires, and i got the rotor but they gave me one for the wrong car but iono if that would cause this.
i also put almost a whole bottle of seafoam in my gas tank to clean the fuel lines and injectors.
please help me asap
next thing i'm going to check is my fuel filter, you think this might be the cause?
Modified by dthug at 11:39 AM 12/13/2006
Old Dec 13, 2006 | 07:41 AM
GG99's Avatar
Default Re: my car stops accelerating while moving HELP ASAP (dthug)
hmmm im not really an expert
but have u checked your TB, and TB cable, maybe its getting stuck or snagged somewhere?
Old Dec 13, 2006 | 07:44 AM
dthug's Avatar
Default Re: my car stops accelerating while moving HELP ASAP (GG99)
yupp i had a friend sit in my car and press the gas and i checked it throttle open up fine
imma go reroute my tb cable tho just in case
anyone think it could be my fuel pump filter?
i'm all out of ideas
Old Dec 13, 2006 | 06:59 PM
dthug's Avatar
bumppppp
Old Dec 13, 2006 | 09:08 PM
JDMFantasy2k's Avatar
so is it like a bucking kind of surging? Don't move the cable, there shouldn't be any reason it's messed up, especially if you can see the throttle body moving unrestricted. Clean inside the TB and after that i'd start checking your O2 sensor.
Old Dec 14, 2006 | 02:45 PM
dthug's Avatar
Default Re: my car stops accelerating while moving HELP ASAP (JDMFantasy2k)
bump for some help
you think i could have a pinch fuel lneor somethng cuz i had passengers tell me they smell gas. would have cause a big enough lost of fuel pressure to make it drive like this
you think since i'm running a stock ls computer my motor is no longer getting enough fuel for a 2.0L instead of 1.8?
Old Dec 15, 2006 | 01:50 AM
dthug's Avatar
bump before schoool
Old Dec 15, 2006 | 03:38 AM
Syndacate's Avatar
I'm sorry, I just g2 bash it...
So...
Car stops accelerating when moving, eh?
What about when it's standing still, does it stop accelerating then?
Well for starters get the right rotor/cap/wires/plugs for your car.
If it's still doing it then then check fuel filter, then fuel pump.
Sounds like a fuel pump problem I suppose, you can check the fuel at the fuel rail and see, it's either not getting fuel, or not getting good sparks.
So change out the normal tune-up, and if it's still doing it check your fuel pressure.
Old Dec 15, 2006 | 11:12 AM
dthug's Avatar
Default Re: (Syndacate)
changed out the car/rotor and all that good stuff i even changed my map sensor just cuz i had a extra one lying around
how would i go about checking my fuel filter to see if its bad?
i dont know what else could be wrong with it i was almost sure it was cuz of the spark but now i think fuel
Old Dec 17, 2006 | 12:03 PM
dthug's Avatar
Default Re: (dthug)
jus changed the fuel filter STILL doing the same exact problem
what could it be i'm loosing patience with this car
Old Dec 17, 2006 | 12:36 PM
dthug's Avatar
Default Re: (dthug)
reading up now i assume it COULD actually be a bad o2 sensor.
when i first got my swap i the o2 sensor wires were cut in half so i spliced it back up and reused it. it ran fine for the 3 weeks i had it and i threw no codes and NOW outta no where my car started to drive like ****
so i read up on fauly o2 sensors and then i went out and unplugged the o2 sensor started it up now i'm throwing a code. i drove around the block a few times and now once did it sputter.
how bad is it if i drove my car around like this for a while until i get a new o2 sensor i also want to be 100% sure its this cuz they aren't cheap
Old Dec 17, 2006 | 12:39 PM
EJAYATE's Avatar
I Deliver
You check the IACV yet? My car did that same thing when I had my IACV unpluged.
Old Dec 18, 2006 | 02:08 PM
dthug's Avatar
Default Re: (B2CivMan)
found out the problem
turned out to be o2 sensor
Rushipn
Honda Civic (2001 - 2005)
Jun 13, 2011 06:46 AM
KraziCivicSi
Jun 30, 2008 05:27 AM
1kleenef
10
Oct 22, 2007 06:30 PM
gourley
Aug 14, 2006 08:45 AM
type Gendy
Oct 12, 2003 09:05 AM
