b16 ob2 swap problem
Old Dec 12, 2006 | 09:34 PM
jdmeg9's Avatar
Default b16 ob2 swap problem
just did a b16 swap in a 96 dx car started right up suprisingly since i had to extend the tps, repin the distributor, change the plug on the alternator, run all the stuff for vtec exc exc.
got the swap from hmotors came with a broken knock sensor and they actually took the tps sensor off of the throttle body. haven't messed with the tps sensor any but, i reinstalled it, when i start it it idles okay, a little rough but when i give it a tap on the gas it wants to choke whether it is hard or a soft tap, but when i give it a gradual go it when take it for a minute then choke out. i am pretty sure it is the tps sensor since it is going with the change of throttle. oh also it is a obd1 swap with a obd2a to obd1 conversion. won't let me check a code through the blue plug above with ecu either.
water in the spark plugs too from jerks steaming the motor
Old Dec 13, 2006 | 02:35 AM
jdmeg9's Avatar
Default Re: b16 ob2 swap problem (jdmeg9)
ne1?
Old Dec 14, 2006 | 02:39 AM
jdmeg9's Avatar
nobody has a clue?
MIGPA26
Mar 11, 2010 08:25 AM
jdmeg9
Dec 17, 2006 06:58 AM
black99x
Sep 7, 2006 03:02 PM
hxtasy
Nov 17, 2004 02:43 PM
type Gendy
Mar 7, 2003 10:12 AM
