what's better for hid's?
Old Dec 11, 2006 | 04:57 PM
perseverance's Avatar
Default what's better for hid's?
i've got a 97 ek and i'm thinking about hid's. what's better for the light output.. stock headlight housings or some projectors from ebay?
Old Dec 11, 2006 | 04:59 PM
TurboTagTeam's Avatar
Default Re: what's better for hid's? (perseverance)
HID are allways brighter. But, that is not necessarily a good thing. An unproperly set up HID kit can blind other drivers comming towards you. THe only safe and pratical HID set-up is a retrofit with OEM HID from another car.
SEARCH!!!!!!!!!! THere is a huge thread about this.
Old Dec 11, 2006 | 05:22 PM
that wasn't the question... the question is which is better to retrofit with. oem civic headlight or the projector headlights on ebay?
Old Dec 11, 2006 | 07:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">i've got a 97 ek and i'm thinking about hid's. what's better for the light output.. stock headlight housings or some projectors from ebay?</TD></TR></TABLE>
Were did you say anything about retrofit????
It really wouldn't matter wich light you use. You have to remove most of the lense for the retrofit anyway.
Old Dec 11, 2006 | 07:20 PM
JDM-EJ1's Avatar
Default Re: (perseverance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">that wasn't the question... the question is which is better to retrofit with. oem civic headlight or the projector headlights on ebay?</TD></TR></TABLE>
If you had to pick from those two, I would use the OEM housing. I'm going to use the H4H HID conversion from http://www.camp1320.com on my JDM housing lights. I know that the light output with be 10x better if I retrofitted projectors from an Audi, BMW, etc; but I don't have the time to do that.
Old Dec 11, 2006 | 07:40 PM
vtec4lyfe's Avatar
buy the projector housings in my sig and retrofit your oem headlights. **** is cheap!
projector ray with regular bulb
pm me if your interested, sorry im not trying to steal your thread
Old Dec 11, 2006 | 08:17 PM
Thizzed Out's Avatar
Default Re: (vtec4lyfe)
doesnt matter if your retro fitting...but OEM does look better.
Old Dec 11, 2006 | 08:21 PM
Civicman86's Avatar
one thing to though is the projector lights usually have a clearer lens. The oem might break the light up some. Im going to try to swap the lens from the projector housing onto a OEM back. We will see what happens.
Old Dec 11, 2006 | 08:30 PM
Default Re: (Civicman86)
ek headlights are pretty clear tho. if he had an EG then yeah swap lense
Old Dec 11, 2006 | 09:29 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Sounds like you are asking which housing is better to just slap some HIDs into, right? Not which is better for a retrofit...
Anyway.. If you can get the gas chamber of the HID bulb to sit exactly where the halogen chamber sits, you can theoretically get pretty good results from after market projectors. Notice: I only read about a guy doing this and getting good results, I have no experience actually doing it [though I started the process once and had to give up due to funds].
Anyway.. Your best bet is to do an OEM HID projector retrofit into either the stock housing or after market projector housings. They will probably work the same [assuming both have clear lenses]. However, it would probably be easier to swap the foglight projector from the after market projectors with the OEM HID projector...
Old Dec 11, 2006 | 11:23 PM
Blink_me92's Avatar
i saw some people who actually install ACURA's TL HID straight to the OEM lights to civic...does that really work? any modification involves?
Old Dec 11, 2006 | 11:39 PM
bpr0422's Avatar
Default Re: (Blink_me92)
Why do noobs never look at stickied threads?!
FAQ Thread: https://honda-tech.com/zerothread/642479
Link in FAQ Thread:
HID Thread: https://honda-tech.com/zerothread?id=683685
End of Thread
Old Dec 12, 2006 | 08:14 AM
H-T Poker champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blink_me92 &raquo;</TD></TR><TR><TD CLASS="quote">i saw some people who actually install ACURA's TL HID straight to the OEM lights to civic...does that really work? any modification involves?</TD></TR></TABLE>
That's what I currently have.. You need at least some Casper H4 Shields for that set up, but you get the shitty stock beam pattern and a fair amount of glare.. You'll have to aim your headlights pretty much as low as they can go or you'll blind people..
Old Dec 12, 2006 | 10:01 AM
marshun's Avatar
Default Re: (Hatchy-Ownzjo0)
so youre wondering if you should buy some ebay projectors and put HID's in'em?
i've never had ebay projectors so i couldnt tell you. but the stock headlights with hid's make crazy glare
Old Dec 12, 2006 | 10:51 AM
Blink_me92's Avatar
so basically any civic can use any HID from ACURA TL (4300k) ..are those just plug in and play...i noticed theres is no ballast.....so its just like installing a regular lamp but we ought to use the H4 casper for the bulb to sit on...right?
sorry im a beginner...thats why i join this forum...
Old Dec 12, 2006 | 05:46 PM
nope not plug and play...you need TL projectors, ballasts, d2r bulbs, and a h4 harness. You should also go join hidplanet.com they can help you alot.
Old Dec 12, 2006 | 07:45 PM
EFATE16
Guest
Posts: n/a
Default Re: (Thizzed Out)
the_dxB16
Lighting
10
Jan 11, 2009 10:10 PM
patrickstar
Lighting
Nov 28, 2007 05:48 AM
DAVE15401
Apr 13, 2007 04:58 PM
dek1mfk
Audio / Security / Video
Sep 8, 2005 08:27 PM
miksew
Oct 8, 2003 04:57 AM
