speedometer not working all the time
Old Dec 11, 2006 | 01:42 PM
nomoreavril's Avatar
Default speedometer not working all the time
it works when it wants to.
its an aftermarket cluster but i dont know what brand, was on the car when i bought it. rpm/fuel work, just not the speedometer. i already took it apart and the cables to the cluster are fine
what do i need to do?
Old Dec 11, 2006 | 01:46 PM
B16B_coupe's Avatar
HRD PKR
Default Re: speedometer not working all the time (nomoreavril)
what year and make and model car? duh
Old Dec 11, 2006 | 01:49 PM
88rexA6's Avatar
one of my friend's integra speedo did that (gsr cluster in an LS integra). we had a spare vss that was known to be good, and that didn't change anything. i think that particular speedo was sticking or something. yours sounds similar. take out the speedo itself (out of the cluster) and check to make sure nothing is crapped up in there.
also, if you have vtec, does it ever not engage?
Old Dec 11, 2006 | 01:55 PM
D16SohcVtec's Avatar
Check the connector to the VSS. Make sure it's not damaged and tight. Just take it off and put it back on and make sure it clicks in. My speedometer use to do that, but that was because the connecto to the VSS is damage and the ground kepted getting loose and popping out of the connector itself.
Old Dec 11, 2006 | 02:04 PM
2coupes's Avatar
my EJ2 did this, changed the cluster, it works fine now
Old Dec 11, 2006 | 02:11 PM
oh sorry, its a 93 civic coupe ex 1.6l sohc i dont think its vtec, but i'm not sure.
Old Dec 11, 2006 | 02:12 PM
its just my work car(delivery for pizza hut) i own a cobalt but i put too many miles on it, so i bought this car for 500
Old Dec 11, 2006 | 02:20 PM
88rexA6's Avatar
Default Re: (nomoreavril)
lol if it's stock, it has vtec. should be a d16z6 motor, but anyway....
once it warms up, does it rev limit at around 7200, or early around 5800? if it limits early, vtec isnt engaging, and the ecu isn't getting a signal from the vss (this is all assuming you aren't throwing a CEL code). if vtec engages all the time no problem, it's most likely your cluster
edit: shouldnt he be throwing code 17 if the vss was messing up at all?
Old Dec 11, 2006 | 02:27 PM
no i can hit 7k easy. like i said though i took it out and it plugs in fine and everything. occasionally the speed comes on but its mostly off. where does the other end plug into? the tranny? maybe thats loose. because one time the second i shifted into third(which btw the synchro is messed up on, grinds unless i rev to 3k before putting it in) it went off.
Old Dec 11, 2006 | 03:39 PM
crazi92hb's Avatar
sounds like you got a bad connection somewhere in the vss wiring my old hatch did the same until i swaped out the harness
Old Dec 11, 2006 | 04:02 PM
platinumx6's Avatar
Mine is still like this, everything but the speedo. I took it to the shop because i couldnt figure it out and they said it is either the wiring harness for that is fried or the speed sensor itself is fried
siregcivic
Oct 10, 2011 10:43 AM
aziaticvang
Jan 8, 2008 06:41 PM
hondaboy4life
Oct 9, 2006 09:35 AM
EK SQUAD 425
May 10, 2006 03:28 AM
Built B18ABorC
Oct 26, 2004 05:41 PM
