Car Idling wierd
Old Dec 9, 2006 | 01:23 PM
mzaner's Avatar
Default Car Idling wierd
Car is a 91 CRX Si, B16A, PR3 ECU.
Just yesterday I noticed that when my car gets warmed up it idles at 800 RPM for a second, then drops to about 400 RPM, then back up to 800 and just keeps repeating til I give it some gas. It also does this when the car is cold, but it always went away when the car wamed up, until now. I have checked the vaccum lines, reset the ECU, disconnected and reconnected the EACV, and it's still doing it, I'm also not getting any CEL's. Does anybody know what could be causing this?
Thanks in advance.
Old Dec 9, 2006 | 02:29 PM
crex23's Avatar
Default Re: Car Idling wierd (mzaner)
Might need to check for low coolant or air in the cooling system.
Old Dec 9, 2006 | 02:41 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Car Idling wierd (crex23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crex23 &raquo;</TD></TR><TR><TD CLASS="quote">Might need to check for low coolant or air in the cooling system.</TD></TR></TABLE>
If you're not getting a CEL for the IACV, I'd bet this is the case as well. Or you could just try cleaning the IACV with carb cleaner while you're at it.
Old Dec 9, 2006 | 03:34 PM
1989CivicSi's Avatar
Default Re: Car Idling wierd (wiZCo)
I have the same problem and believe it to be air in the coolant lines...haven't really had time to check it out yet though. Just need to purge the coolant system of air and check it out.
Let me know via PM or this thread how/if you ever fix your problem, because I have the same issue!
Old Dec 13, 2006 | 10:30 AM
b16hondarex's Avatar
check out some of the other idle problem post. i posted what the problem 9 times out of ten is and how to fix it.
vtec25
Feb 8, 2007 06:44 PM
mikeym
Jan 25, 2007 09:19 PM
maxboost_50psi
Jul 7, 2005 07:11 PM
130R
17
Dec 27, 2004 07:07 PM
mdj_ge
Jul 18, 2004 08:31 PM
