a/c help
Old Jul 6, 2005 | 06:52 PM
maxboost_50psi's Avatar
Default a/c help
i got this problem with my a/c when the car is at operating temperature and the car isnt moving the a/c doesnt cool as good as if the car was moving are there anythings i should check i think i might it might be low in coolant. thats just onething idk if maybe the compressor is bad but it turns on and cools the car very well when its moving but when its at idle in a parking lot or drive thru it start to blow hot air. can someone please help me thanks
Old Jul 6, 2005 | 07:23 PM
GSR_YEAGER's Avatar
Default Re: a/c help (maxboost_50psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxboost_50psi &raquo;</TD></TR><TR><TD CLASS="quote">i got this problem with my a/c when the car is at operating temperature and the car isnt moving the a/c doesnt cool as good as if the car was moving are there anythings i should check i think i might it might be low in coolant. thats just onething idk if maybe the compressor is bad but it turns on and cools the car very well when its moving but when its at idle in a parking lot or drive thru it start to blow hot air. can someone please help me thanks</TD></TR></TABLE>
most likely your fan/s arent kicking in. when you drive air blows through your radiator/condincer and keeps it cool. your car has two fans one on the condincer/radiator, and one on the radiator. so if your car is overheating then neither are kicking in, but if its normal temp then only your condincer fan isnt kicking in.
Old Jul 6, 2005 | 07:52 PM
yea the fans are working for sure they are FAL fans brandnew they turn on but i think i need to put in some more coolant
Old Jul 6, 2005 | 08:38 PM
GSR_YEAGER's Avatar
Default Re: (maxboost_50psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxboost_50psi &raquo;</TD></TR><TR><TD CLASS="quote">yea the fans are working for sure they are FAL fans brandnew they turn on but i think i need to put in some more coolant</TD></TR></TABLE>
why would coolant have anything to do w/it? do you mean freon? if so you should'nt need it. if you ac cools while you are driving then it should cool at a stand still........if your fans work
Old Jul 7, 2005 | 02:58 AM
drussell4801's Avatar
Default Re: (GSR_YEAGER)
things that cause hot air while trying to get cold A/C:
bugs, and debris in your condensor.
fans not working
air blend door not working properly (whether its cable misadjustment or vacuum line problems)
and other less likely problems.
edit: rev it up next time you're sitting still. If revving it helps, then you may need to top it off with refrigerant.
Modified by drussell4801 at 7:33 AM 7/7/2005
Old Jul 7, 2005 | 05:32 AM
air blend door whats that?
Old Jul 7, 2005 | 05:52 PM
its inside the air box under the dash. it blends the heat and A/C properly to give you the right temperature air coming out the vents.
get a helm manual.
Old Jul 7, 2005 | 06:57 PM
helm?
Old Jul 7, 2005 | 07:11 PM
DB8_TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxboost_50psi &raquo;</TD></TR><TR><TD CLASS="quote">helm?</TD></TR></TABLE>
its a manual that tells you how to fix/take apart everything in your integra. great investment
quick question, where is the compressor located in 94+ integras?
simplypinoyy
Jul 29, 2008 05:53 AM
Schultzie
Aug 11, 2007 02:32 PM
GREENMOB$TER
Feb 8, 2007 09:15 PM
miamiracer23
May 7, 2006 08:11 AM
H.A.R.T b16a1crx
18
Oct 21, 2004 12:09 PM
