T3/T67 with a InlinePRO Manifold?
I was wondering if the T3/T67 would fit with the InlinePRO Manifold with A/C. Does anyone have pictures of a t3/t67 next to an sc61 or something. Anyone do this before?
Been done quite a bit actually. Depending upon the chassis and setup, it may be wiser to locate the compressor side on the side of the driver for a bit easier access. The T67 is much more of a top end variant than the SC61. Both do well in top end power, but its all in what you're looking for.
A t3/t67 and a sc-61 with a S cover are the same size. But I dont think they have the t3/67 with an e-cover like the sc-61 has.
E-cover= 3 inch inlet/ 2 inch outlet
S-cover= 4 inch inlet/ 2.5 outlet
Adriano
Adriano
just becasue they have the same housings in no way mean they are the same size
sc61 61mm 2.416" 3.227" 56 4" / 2.5"
t3/t67 67mm 2.620" 3.310" 63 4" / 2.5"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">just becasue they have the same housings in no way mean they are the same size
If you paid more attention to the first post, you would know that he's talking about the physical size. Reading is the key my friend.
Adriano
Adriano
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">Been done quite a bit actually. Depending upon the chassis and setup, it may be wiser to locate the compressor side on the side of the driver for a bit easier access. The T67 is much more of a top end variant than the SC61. Both do well in top end power, but its all in what you're looking for.</TD></TR></TABLE>
It will be in a 00Si with Air conditioning. I dont mind shaving the block a little for the S housing.
I had the sc61 and cleared changed to the t3/60-1 with S housing and it didnt clear!! i think the t67 is the same as the 60/1 turbo!! goodluck!
Yeah pretty big difference. I have a BB T67/t3 and that sh... hits hard. The SC61 which I had before is a very nice street/strip turbo. Street car SC61, Street/Track t67/t3. For both turbos make sure the compressor faces the drivers side you'll thank me for it later! For my setup SC61 made 308whp on 9lbs and T67/T3 .63 P-trim made 350whp on 9lbs. with injector problems 13.3 afr's. And one other thing 4 bolt back housing, V-band would be better.
my set up:
https://honda-tech.com/zerothread?id=1793282
Modified by VtecCarHauler at 8:02 PM 12/9/2006
Modified by VtecCarHauler at 8:03 PM 12/9/2006
Modified by VtecCarHauler at 8:05 PM 12/9/2006
Modified by VtecCarHauler at 8:06 PM 12/9/2006
my set up:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecCarHauler »</TD></TR><TR><TD CLASS="quote">Yeah pretty big difference. I have a BB T67/t3 and that sh... hits hard. The SC61 which I had before is a very nice street/strip turbo. Street car SC61, Street/Track t67/t3. For both turbos make sure the compressor faces the drivers side you'll thank me for it later! For my setup SC61 made 308whp on 9lbs and T67/T3 .63 P-trim made 350whp on 9lbs. with injector problems 13.3 afr's. And one other thing 4 bolt back housing, V-band would be better.
my set up:
Modified by VtecCarHauler at 8:06 PM 12/9/2006</TD></TR></TABLE>
Looks good but im trying to cram this all into my 00Si with a/c and p/s.
Therefore i need the 5bolt and the compressor side has to be on the passenger.
my set up:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS »</TD></TR><TR><TD CLASS="quote">If you live in the orlando area you can come by and check if a s-housing turbo will fit.</TD></TR></TABLE>
Thanks, but im down south.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adriano »</TD></TR><TR><TD CLASS="quote">A t3/t67 and a sc-61 with a S cover are the same size. But I dont think they have the t3/67 with an e-cover like the sc-61 has.
Adriano</TD></TR></TABLE>
I can get a Precision PT67 with a T3 turbine and also an E compressor cover just fyi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com »</TD></TR><TR><TD CLASS="quote">
how much $$?
</TD></TR></TABLE>how much $$?
PM me a price. If it dosent fit can i send it back for a diff turbo?
Im going to see if any local shops have a t3/t67 s housing that i can test fit, pm me a price for the S housing also.
</TD></TR></TABLE>PM me a price. If it dosent fit can i send it back for a diff turbo?
