correction of prev posting(need help with timing on US/J DM mix)
Old Dec 8, 2006 | 02:33 PM
HondaHeddie's Avatar
Default correction of prev posting(need help with timing on US/J DM mix)
the original thread is here:
https://honda-tech.com/zerothread/1832366
now the issue
as far as setting the timing:
I cant find the connector the helms manual says to jumper
it says it is in the "left rear" of engine compartment.
does someone have a picture?
and what about my JDM engine w/ USDM crank pulley?
are the marks in the same place?
do I still set it to the red mark like the helms says for the USDM or should it be diferent for the JDM engine?
I failed emmissions so I am trying to knock everything out that I can
Old Dec 8, 2006 | 03:34 PM
Default Re: correction of prev posting(need help with timing on US/J DM mix) (HondaHeddie)
bump
for timing connector pic
and
will us pulley match j motor?
Old Dec 8, 2006 | 06:41 PM
boing
Old Dec 9, 2006 | 10:56 AM
bump
Old Dec 9, 2006 | 02:06 PM
Thanks for all the help guys
I got a variable timing light and set the timing by the tdc mark which I assume is the same even if the other 3 marks are different from market to market.
I jumpered the connector in the outside corner of the passgr floorbrd, it seems to have the right color wires even if it is in a completely different location than the helms manual says.
But then the last step on page 23-58 says to replace the rubber cover on the timing adjuster screw. Which it never says to remove, use, or even identifies.
So I guess even Helms manuals aren't perfect.
off to my next thread
jesshaines
10
Aug 14, 2017 04:31 AM
phrenzykEG6
May 7, 2010 05:24 PM
jchrm80
Dec 22, 2007 05:14 PM
spoolin_teg
Feb 13, 2007 04:49 PM
