High Idle and boost creep from 7k-9k
Old Dec 8, 2006 | 01:54 PM
1FastCoupe's Avatar
Default High Idle and boost creep from 7k-9k
I installed my new tubular manifold and my car ran fine for about 20 minutes. The car used to Idle at 1k and now it idles at 2k with a little fluctuation from 1.5k.. I also noticed last night that the car was running on 20psi fine and then all the sudden from 7k - 9k it creeps fast to 30psi.. Any ideas? I thought it was a vaccum leak but everything seems to be fine. Whats a good way to test for a vaccum leak as well?.The setup is as follows.. Its a precision sc61 with a full-race style manifold made from a local shop..Tial 38mm wastegate, 3in DP..Hondata.. I just don't know where else to look at this point. Thanks in advance.
Old Dec 8, 2006 | 02:04 PM
urbansi's Avatar
Default Re: High Idle and boost creep from 7k-9k (1FastCoupe)
Let the tuner deal with it once its on the dyno, you cant just throw on new parts and expect everything to be ok.
Retune
Old Dec 9, 2006 | 12:38 PM
1FastCoupe's Avatar
Theres got to be more to it then that.. Even on low boost it goes to 15psi then around 7k to 9k it creeps fast to 25-30psi.. My vacuum sources seem to be just fine.. Maybe the gain needs to be lowered?
Old Dec 10, 2006 | 07:09 AM
1FastCoupe's Avatar
I tried search but nothing..
Old Dec 10, 2006 | 08:33 AM
mar778c's Avatar
Community Builder
Community Influencer
Re-check for leaks.
dcalsv02
Aug 31, 2013 08:20 AM
jaredvabeach
Jan 14, 2010 08:15 PM
vtak2nr
Aug 27, 2009 03:59 AM
8200RPM
Dec 22, 2004 10:02 PM
paul93sir
Feb 10, 2004 05:30 AM
