ground wires?
Old Dec 7, 2006 | 11:18 PM
jizzer671's Avatar
Default ground wires?
how many ground wires in an integra gsr are there? also should the ground wire from the battery be grounded to the block?
Old Dec 8, 2006 | 12:13 AM
jizzer671's Avatar
Default Re: ground wires? (jizzer671)
a mechanic said i should have the the ground wire coming from the battery and being grounded to the block. is this true? im asking because its currently being grounded to the chassis.
Old Dec 8, 2006 | 12:20 AM
97itypeR's Avatar
idunno if im right but ive always herd, just make sure u ground to sometthing thats non electrical, so im guessing the block or chassis is fine?
Old Dec 8, 2006 | 02:23 PM
Sam92Teg's Avatar
Default Re: (97itypeR)
On my 92 RS, the ground cable off of the batter goes under the battery tray and grounds to the chassis, but then continues and grounds to the tranny. So it grounds to both the chassis and tranny. Is that how your newer cars are?
Old Dec 8, 2006 | 02:31 PM
akandok's Avatar
battery grounds right on the strut tower. there is ground wire from chassis to tranny and chassis to the valve cover
Old Dec 8, 2006 | 02:59 PM
Sam92Teg's Avatar
Default Re: (akandok)
Wow, so on the newer tegs, the battery ground wire goes to the shock tower? My negative battery cable goes under the battery tray to the front lower fender and grounds there, then continues to the tranny.
The only wire that goes near the shock tower on my 92 RS is the positive cable that splits in two, one wire to the under hood fuse box (near shock tower), and the other wire to the starter.
Old Dec 8, 2006 | 03:07 PM
akandok's Avatar
Default Re: (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">Wow, so on the newer tegs, the battery ground wire goes to the shock tower?
yep
Old Dec 8, 2006 | 04:39 PM
JDM_DC4_Fanatic's Avatar
The motor needs to be grounded one way or another. So, either you groud it directly from the battery, or you ground the batter to the tranny, or you ground the batter to the chassis, then to the tranny/block. Either way you do it, the motor needs groundn and the chassis needs ground.
Old Dec 8, 2006 | 05:03 PM
Sam92Teg's Avatar
Default Re: ground wires? (JDM_DC4_Fanatic)
I just want to know how the newer tegs ground the battery cable from the factory.
Old Dec 8, 2006 | 07:50 PM
99Geeezer's Avatar
Default Re: ground wires? (Sam92Teg)
Mine is grounded to the shock tower(body). The body is then grounded at the transmission. and since the motor is bolted to the tranny, the engine now grounded. I've since then added a few of my own ground straps using high quality low resistance stereo cables with gold plated rings. Firewall to intake manifold. Cylinder head to radiator support. And rad. and a couple more but too many too list. I found this to be cheaper than buying a grounding kit.
Old Dec 8, 2006 | 10:45 PM
spikehairboy's Avatar
yeah just buy some welding wire google it up its pretty cheap and does the job
Old Dec 9, 2006 | 08:09 PM
jizzer671's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akandok &raquo;</TD></TR><TR><TD CLASS="quote">battery grounds right on the strut tower. there is ground wire from chassis to tranny and chassis to the valve cover</TD></TR></TABLE>
thank you! that answers my question...thats just the way i see it in my teg.
nonpareil
Mar 12, 2010 04:58 AM
hb_guy
Apr 9, 2006 06:43 PM
crxh22project
Mar 14, 2005 04:52 PM
96b18c
Jun 3, 2004 07:29 PM
wannab20hatch
Oct 12, 2002 10:15 AM
