siezing calipers!!!
Old Dec 7, 2006 | 12:15 PM
ejmatzell's Avatar
Default siezing calipers!!!
just wondering if anyone else has this problem... is it relatively common? I replaced my left rear caliper after it siezed this past summer and now my right rear is starting to show the same signs. so annoying... in total probably about $500 (since the first one was around $250) in total for both calipers! anyone?
Old Dec 7, 2006 | 12:21 PM
reno96teg's Avatar
Default Re: siezing calipers!!! (ejmatzell)
both of my rear calipers were basically frozen because all of the slider pins got way too gunked up to move.
with some effort, i removed the slider pins, cleaned all of the crap out, greased them up, and now they're as good as new.
cost: brake cleaner fluid + anti-seize lube
edit: i actually need to get new dust boots for the sliders as well. can't find the part #'s..
Old Dec 7, 2006 | 01:12 PM
ejmatzell's Avatar
Default Re: siezing calipers!!! (reno96teg)
awesome... i'll have to try that. my only problem is i'm at school 14 hours away from home and don't have the parts to do it myself. but, if i wait too long, it will sieze up. thanks for the help
Old Dec 7, 2006 | 01:54 PM
Brick Top's Avatar
$250? did you not a have a core to return? sounds awful expensive.
Old Dec 7, 2006 | 03:13 PM
Sam92Teg's Avatar
Default Re: siezing calipers!!! (brick top)
I think I paid $58 for a rebuilt one from Autozone.
Old Dec 7, 2006 | 03:15 PM
ejmatzell's Avatar
parts alone were $160 from acura... 2 hours of work.
Old Dec 7, 2006 | 07:12 PM
99Geeezer's Avatar
seized piston or bolts?
Old Dec 7, 2006 | 09:20 PM
ejmatzell's Avatar
Default Re: siezing calipers!!! (99Geeezer)
the whole caliper was shot
Old Dec 7, 2006 | 11:00 PM
jizzer671's Avatar
same thing is currently happening to me. i replaced the right rear 2 months ago...i was told that i should just replace both(recomended) now the left rear is going out. just scored it from auto zone $139w/ $52 core charge. now have to diy.
Old Dec 8, 2006 | 09:51 AM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejmatzell &raquo;</TD></TR><TR><TD CLASS="quote">parts alone were $160 from acura... 2 hours of work. </TD></TR></TABLE>
a caliper is very simple to change. why pay someone to do it for you?
Old Dec 8, 2006 | 10:33 AM
PrinceAli132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reno96teg &raquo;</TD></TR><TR><TD CLASS="quote">edit: i actually need to get new dust boots for the sliders as well. can't find the part #'s.. </TD></TR></TABLE>
I am not sure if they sell them seperatly, but I believe they are included in the caliper rebuild kit.
Ali
Old Dec 8, 2006 | 11:40 AM
efvader's Avatar
Default Re: siezing calipers!!! (PrinceAli132)
def a common prob on older acuras/hondas.. we sell them here quite a bit
and you can get the dust boots in the rebuild kit pn 01463-ST7-000
Old Dec 8, 2006 | 02:44 PM
Mad Money's Avatar
Default Re: siezing calipers!!! (civicdxtyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">
a caliper is very simple to change. why pay someone to do it for you?</TD></TR></TABLE>
Its not as easy as u make it seem. Most of the times the bolts are rusted to ****, and EBRAKE clips are PITA to remove. The brakes will needed to bled all the way around, also u have to be extremly careful not to kink the the brank lines when working on the calipers. I guess if u are a mechanic for a living its easy, but otherwise it is somewhat time consuming.
Old Dec 8, 2006 | 03:51 PM
JDM_DC4_Fanatic's Avatar
Rebuild FTW
Old Dec 8, 2006 | 11:40 PM
vladd's Avatar
Default Re: siezing calipers!!! (Mad Money)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mad Money &raquo;</TD></TR><TR><TD CLASS="quote">
Its not as easy as u make it seem. Most of the times the bolts are rusted to ****, and EBRAKE clips are PITA to remove. The brakes will needed to bled all the way around, also u have to be extremly careful not to kink the the brank lines when working on the calipers. I guess if u are a mechanic for a living its easy, but otherwise it is somewhat time consuming.</TD></TR></TABLE>
i've never taken the rear calipers off, so i don't know about the ebrake cables, but i replaced my front rotors yesterday and the front calipers took like a minute each to take off. bleeding brakes isn't very hard, just gotta have a friend to help. i'm not a mechanic or anything, but a lot of maintenance crap is easy to do if you learn how.
Old Dec 8, 2006 | 11:57 PM
__oversea's Avatar
Default Re: siezing calipers!!! (JDM_DC4_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">Rebuild FTW </TD></TR></TABLE>
its pretty easy. just watch out when you blow off the piston mad force
Old Dec 9, 2006 | 04:38 AM
Default Re: siezing calipers!!! (ZeroTalent)
How-to rebuild your calipers (scroll down for the rears)
Edit - forgot to add the link
http://www.performanceforum.co....html
Ali
Modified by PrinceAli132 at 7:05 PM 12/9/2006
Old Dec 9, 2006 | 10:21 AM
ejmatzell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">a caliper is very simple to change. why pay someone to do it for you?</TD></TR></TABLE>
I know it's simple, I'm at school 14 hours away from home... not so simple without tools
Old Dec 9, 2006 | 11:54 AM
vladd's Avatar
I know it's simple, I'm at school 14 hours away from home... not so simple without tools</TD></TR></TABLE>
the money you could've saved on labor could've bought you a simple tool set.
Old Dec 9, 2006 | 02:57 PM
ejmatzell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">the money you could've saved on labor could've bought you a simple tool set.</TD></TR></TABLE>
ok... i'm an idiot for paying $80 in labor charges knowing that the job was done correctly, not buying a "simple" toolset that i would have to lug ALL the way back home in my small integra (packed to the top as it is and toolsets aren't light), and not doing the job in the parking lot of my campus. next time, i'll do it myself. and how simple of a toolset are we talking here?
Ihatedomestic
Jun 19, 2016 01:59 PM
mynameisChris
Aug 15, 2009 06:57 AM
PreludePhill
Apr 28, 2006 06:37 PM
95TEG
Jun 11, 2005 07:37 AM
SonicGSR
Mar 31, 2003 05:55 PM
