HOW MUCH POWER WILL A T3/T4 AR.50 turbo make
Old Dec 5, 2006 | 06:05 PM
IT'S ME DAVID's Avatar
NooB
Default HOW MUCH POWER WILL A T3/T4 AR.50 turbo make
Any info about this size turbo is helpful.Its a non ball bearing of course.I think xs.i went to there site but could not find it.it will be going on a b20/vtec 38mm wategate cast iron manifold with revhar intake manifold.t3/t04e
Modified by IT'S ME DAVID at 12:15 AM 12/6/2006
Old Dec 5, 2006 | 07:13 PM
NooB
Default Re: HOW MUCH POWER WILL A T3/T4 AR.50 turbo make (IT'S ME DAVID)
tuned on crome.
Old Dec 5, 2006 | 07:39 PM
DCxMagus's Avatar
how much boost?
is the motor stock?
what size injectors?
tubular or log style manifold?
Average temp around your area?
what compression you look at running?
what Octane you going to run?
whats your altitude?
at around 5 PSI with a 50 ar I would say maybe around 240-260whp? depending how aggressively tuned the car is might want to look into the .63 ar for the B20 though
Old Dec 5, 2006 | 11:15 PM
NooB
Default Re: HOW MUCH POWER WILL A T3/T4 AR.50 turbo make (DCxMagus)
stock block 8:8:1 compresion.tubular manifold.gsr head with gsr cams.revhard intake manifold.dont know what size if any are needed for injectors.About 8-10 psi.91 but c16 when racing altitude sucks L.A
Old Dec 5, 2006 | 11:26 PM
Timmay's Avatar
what is the exact trimming of the turbo?
Old Dec 5, 2006 | 11:27 PM
NooB
Default Re: HOW MUCH POWER WILL A T3/T4 AR.50 turbo make (Timmay)
it just says t3/t4 .50 ar
Old Dec 5, 2006 | 11:30 PM
Timmay's Avatar
ok i would probably say anywhere from 350-450whp.. its hard to say w/o knowing the full specs of it
Old Dec 5, 2006 | 11:52 PM
NooB
0.58 5 Bolt Standard Hotside
0.63 A/R Cold
0.57 Cimpressor wheel trim
0.60 A/R Compressor
0.63 A/R Turbine
57 Trim
Old Dec 5, 2006 | 11:53 PM
Timmay's Avatar
probably gonna be maxed out at 450whp range
Old Dec 5, 2006 | 11:54 PM
NooB
ok thanks.
NooB
ok thanks.
Old Dec 6, 2006 | 01:36 AM
RevTek 6's Avatar
im gonna say around 450.
Old Dec 6, 2006 | 03:06 PM
NooB
Default Re: HOW MUCH POWER WILL A T3/T4 AR.50 turbo make (RevTek 6)
Not bad.
Old Apr 30, 2022 | 09:45 AM
Chachebache's Avatar
is that 450 total or does it add 450 plus wat I already have?
Old Apr 30, 2022 | 10:07 AM
Stopsign32v's Avatar
Loved
What's with all of these 1 post accounts bringing back threads from the dead?
Old Apr 30, 2022 | 10:26 AM
highschooler's Avatar
I don’t know but I think people don’t want to start a new thread because everyone will say, “did you search?”
https://honda-tech.com/announcement.php?f=6&a=10
That says it’s OK to reply to an old post that you have found searching.
Old Apr 30, 2022 | 10:55 AM
To answer the question,
T3/T04E turbos usually don’t have a .50 A/R ratio but there is a common turbo called a 50 trim which is the diameter of the wheel in the compressor(cold side) housing. The exhaust side is typically .48 A/R ratio or .63 A/R ratio. With the smaller A/R ratio you’ll get a quicker spool but worse top end and total power, with the larger A/R ratio you’ll get slower spool time and a bigger total power output.
I’d say with a 50 trim you’ll be lucky to get 450 flywheel horsepower total, probably not 450 wheel horsepower. And that’s a total, not on top of your stock horsepower rating, because all of the air flowing into your engine has to go through the compressor side of the turbo, so it becomes limited with the 50mm sized wheel. You could try a 57 or a 60 trim for a tad more power.
96romaEK
May 11, 2010 08:01 PM
vestalfootball72
Feb 22, 2008 06:48 AM
jdmturbo1127
Apr 5, 2007 09:16 PM
evsproject94
Jul 15, 2006 03:49 PM
1990hondaHF
Aug 9, 2003 04:33 PM
