HOW MUCH POWER WILL A T3/T4 AR.50 turbo make
Any info about this size turbo is helpful.Its a non ball bearing of course.I think xs.i went to there site but could not find it.it will be going on a b20/vtec 38mm wategate cast iron manifold with revhar intake manifold.t3/t04e
Modified by IT'S ME DAVID at 12:15 AM 12/6/2006
Re: HOW MUCH POWER WILL A T3/T4 AR.50 turbo make (IT'S ME DAVID)
how much boost?
is the motor stock?
what size injectors?
tubular or log style manifold?
Average temp around your area?
what compression you look at running?
what Octane you going to run?
whats your altitude?
at around 5 PSI with a 50 ar I would say maybe around 240-260whp? depending how aggressively tuned the car is might want to look into the .63 ar for the B20 though
is the motor stock?
The following 2 users liked this post by Stopsign32v:
https://honda-tech.com/announcement.php?f=6&a=10
That says it’s OK to reply to an old post that you have found searching.
To answer the question,
T3/T04E turbos usually don’t have a .50 A/R ratio but there is a common turbo called a 50 trim which is the diameter of the wheel in the compressor(cold side) housing. The exhaust side is typically .48 A/R ratio or .63 A/R ratio. With the smaller A/R ratio you’ll get a quicker spool but worse top end and total power, with the larger A/R ratio you’ll get slower spool time and a bigger total power output.
I’d say with a 50 trim you’ll be lucky to get 450 flywheel horsepower total, probably not 450 wheel horsepower. And that’s a total, not on top of your stock horsepower rating, because all of the air flowing into your engine has to go through the compressor side of the turbo, so it becomes limited with the 50mm sized wheel. You could try a 57 or a 60 trim for a tad more power.
