what are the symptoms of a bad dizzy
Old Dec 4, 2006 | 11:26 PM
flatblk's Avatar
Default what are the symptoms of a bad dizzy
is there a place where a can test it? 95 ls 5 speed ....
Old Dec 4, 2006 | 11:29 PM
GoldCoin's Avatar
Default Re: what are the symptoms of a bad dizzy (flatblk)
symtoms??? maybe im thinking CEL 15
Old Dec 5, 2006 | 12:14 AM
erikiksaz1's Avatar
Default Re: what are the symptoms of a bad dizzy (DC TWOin IT)
Besides for the scratching, screeching noise inside the unit itself, mine seemed to just kick the bucket one day.
Old Dec 5, 2006 | 07:44 AM
Sam92Teg's Avatar
The distibutor has a bearing and sensors that can fail. But usually, the components inside fail that can easily be replaced. The coil and ignitor/module can be tested and replaced. And the cap and rotor can be visually inspected.
If you have a weak or no-spark issue, test the internal componets. If you are noticing a noise/squeel, pull the cap and inspect the rotor. Is the rotor loose? That could cause the noise.
A bad dist. bearing will cause the rotor to spin off balance and sometimes will eat up the contact points on the cap and rotor. Good luck pinpointing your problem.
b.d.racing
Mar 4, 2008 04:44 PM
JWilley
Jan 26, 2007 12:17 PM
Extreez
Jan 3, 2007 04:33 PM
bleedblue94
Jan 7, 2006 10:08 PM
MantisX
Oct 20, 2005 08:40 AM
