spun at VIR... camber issue? slightly bent susp. peice? 4 big pics
Old Dec 3, 2006 | 05:12 PM
baonest's Avatar
Default spun at VIR... camber issue? slightly bent susp. peice? 4 big pics
ok well it happened so fast, but coming out of the uphill esses i (think) i hit the gator and disrupted the susp and slid across track.. it was on grass, and the track, then back on grass. both instructor and I are A-OK. i slid sideways down the track pass side first facing the tire wall.
but this happened... (we are looking at the front tire, pass one looks like messed up camber)
Driver side rear shot:
Pass. side rear shot:
Pass side front shot:
Drivers side front shot:
i tried to get as strait as possible on the pictures.. there is something obviously wrong, could not spot anything bent our out of the ordinary when i looked under/around the car.
but the steering wheel is off... instead of the steering wheel being strait its probably 20degrees off center pointing to the left...
as in it looks like this \ instead of this |.
but its not at this ( \ ) angle..
pure powR
Old Dec 3, 2006 | 05:28 PM
waddy41's Avatar
ouch
Old Dec 3, 2006 | 06:17 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
Do you have a skunk2 (or any slide balljoint type) camber kit? If yes, most likely it slipped and not a big deal at all.
Old Dec 3, 2006 | 06:30 PM
Chris F's Avatar
Default Re: (Wai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wai &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a skunk2 (or any slide balljoint type) camber kit? If yes, most likely it slipped and not a big deal at all.</TD></TR></TABLE>
That'd be the convenient answer, hopefully that's all it is.
If your steering wheel is off, better check your tie rods etc.
-Chris
Old Dec 3, 2006 | 06:34 PM
baonest's Avatar
Default Re: (Chris F)
no, its completely stock susp setup.
ive seen alot of this at work. ive dealt with a lot of bent susp. peices. i just dont want this to be a "non work" related item cuz i dont wanna pay for it
i looked at those camber arms today, and couldnt find anything. i need a fresh day tomorrow.
i still took it on track after wards, it ran fine, but you could tell something was off.
thanks for the input guys
Old Dec 3, 2006 | 06:42 PM
waddy41's Avatar
uh oh...good luck when u take some stuff apart...
Old Dec 3, 2006 | 06:51 PM
Kevedge's Avatar
Default Re: (waddy41)
Make sure your wheel bearings are still good. My car had the same thing happened, and one wheel had more camber then the other. Also make sure that both sides are equal ride height
Old Dec 3, 2006 | 06:52 PM
baonest's Avatar
Default Re: (Kevedge)
bearings sound and move like they are good.
but ill also check that and the height to make sure we are on even playing field
Old Dec 3, 2006 | 08:07 PM
pyitrboy's Avatar
Just get an alignment and see if anything is bent...might just need toe readjusted.
Old Dec 3, 2006 | 08:09 PM
pyitrboy's Avatar
ooops, my bad didn't see the camber problem you noted. probably just need a
knuckle.
Old Dec 4, 2006 | 04:53 AM
RStoR's Avatar
Default Re: (pyitrboy)
Sory to hear Kourosh but glad to see you're on track. Let me know if I can help in any way.
Old Dec 4, 2006 | 05:34 AM
mikestypeRR's Avatar
Start with an alignment
Old Dec 4, 2006 | 12:24 PM
Hooch'n's Avatar
Default Re: spun at VIR... camber issue? slightly bent susp. peice? 4 big pics (baonest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeRR &raquo;</TD></TR><TR><TD CLASS="quote">Start with an alignment</TD></TR></TABLE>
Yeah, better check your tie rods and etc. Glad you OK, I am guessing you are at 95+ when you went off!? wow, must have happened fast......could have been worse then just alignment issue.
Old Dec 4, 2006 | 03:42 PM
baonest's Avatar
Default Re: spun at VIR... camber issue? slightly bent susp. peice? 4 big pics (Hooch'n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hooch’n &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, better check your tie rods and etc. Glad you OK, I am guessing you are at 95+ when you went off!? wow, must have happened fast......could have been worse then just alignment issue. </TD></TR></TABLE>
yeah. it was around those speeds.
as we were sliding sideways i was thought surely we were gonna at least get two wheels off the ground, if not flip.
Old Dec 4, 2006 | 04:07 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Dude wtf.
Old Dec 4, 2006 | 07:36 PM
baonest's Avatar
Default Re: (v-attack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-attack &raquo;</TD></TR><TR><TD CLASS="quote">Dude wtf. </TD></TR></TABLE>
twas a fun trip though
Old Dec 5, 2006 | 09:40 AM
mstewar's Avatar
if anything is bent I'd bet on it being the knuckle, if only slightly.. definitely a good idea to make sure the tie-rods are alright too.. won't know anything for sure until it goes on an alignment rack..
glad that's all you had go wrong!
Old Dec 5, 2006 | 11:11 AM
ff terror's Avatar
too old for school
Default Re: (baonest)
you can't tell if something is bent just by looking at the outside... take the wheels off and start taking her apart and comparing pieces left/right sides until you identify what is bent.... i wouldn't even start with an alignment because you will have to pay for that unless you are doing it yourself.
Old Dec 5, 2006 | 03:25 PM
paRRRker's Avatar
Default Re: (ff terror)
operator error
end of story.
Old Dec 5, 2006 | 03:45 PM
baonest's Avatar
Default Re: (paRRRker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paRRRker &raquo;</TD></TR><TR><TD CLASS="quote">operator error
end of story.</TD></TR></TABLE>
yeah, im getting it aligned at work tomorrow.
i took the wheels off and quickly looked things over when i was at the track. i have a spare integra parts car, not an R though, so if anything is bent, lets hope its interchangable parts.
Old Dec 5, 2006 | 04:12 PM
Doostur's Avatar
Ouchers!
blaak-crx
Suspension & Brakes
Jul 20, 2011 08:29 AM
ultimatehonda
Jul 8, 2003 03:28 AM
Kelvin96GSR
21
Jan 21, 2003 10:38 AM
vteg
May 22, 2002 06:17 PM
phat-S
13
Aug 30, 2001 10:09 AM
