How much air is supposed to be in the tires?
How much air is supposed to be in the tires for a 17 rim? I have a Honda Civic with new HP Racing Rims. I just want to know whats the normal tire pressure?
Honda Civic 4dr or 2Dr? What model EX. LX. DX??? What Tire Size?
please don't say "they're 17's!"
or "Um They're 40's series"
So how much is supposed to be in it? Is it the normal pressure for stock tires? How much am I suppose to put in?
I work for Discount tire we run 32 psi for all cars , unless the customer requests other wise. Just remember that your tire pressure changes depending on wether they are hot or not.So when we first mount a tire (it's cold) the air pressure is set @32 psi. After you have been driving on them a while the air heats up and expands,changing the air pressure to 3-5 psi more.
Whats going to happen if I run the wheels at the normal psi? Will that hurt tire performance? When I have the tires at 32 psi there too hard and when I go over bumps its pretty loud. If I put it at normal psi which is I think 29 in the front and 28 in the rear... it isnt as loud when I run over bumps. What should I do? Leave it at 32 psi? Do i need to gte coilovers?
jsut put that freaking ammount on the side of the tire in.. ****. or in your case, 2 psi should be enuf.....
but honestly just put 5 psi under the maximum number in.
God damn newbies
but honestly just put 5 psi under the maximum number in.God damn newbies
NEWBIES!!!!!!!!!!!!!!!!!!! ****
hahaha if you don't know about air in your tires, do yourself and the world a favor and don't drive
you belong in a sinking boat with that other newbie MRVTEC.
im sure you came out of the womb with a helms in one hand and a torque wrench in the other, right?
im sure theres alot of things you dont know smart ***.dont diss on him because he dosent know much about cars.
[Modified by KAMiN, 1:31 AM 5/13/2002]
You need to check the max pressure on the side of your tires. If you have 17's then you most likely also have low profile tires too. Many low profile tires require more presure then normal tires, especially to maintain the high speed rating of the tires.
For example, my BF Goodrich Scorcher T/A's can run on anything from about 40-50. But to keep the 150MPH rating of the tire the have to have 50 psi.
If you want the the exact right amount of pressure, try this. Fill your tires to about 5 psi below max. pressure. Then take a piece of chalk and make 4 marks on each tire going from the sidewall to the tread. Take your car for a spin, and try to take a few hard turns. If the chalk has been rubbed off on the sidewalls, you need to add more air. If the chalk is still on the tread you need less air. Try this several times until the chalk only rubbs off the tread and non of the sidewall.
Also do not run different tire pressures on the same axel. It's ok to have different amounts of pressure in the front then the rear, but not different amount from one side to the other.
As for being "stiff" rolling on low 17s will be stiff. And because it's wide, it will generate a lot more tire noise. You can't avoid it. That's why I got 15s instead. If you have not gotten wheels, think about it. It's ok for some, but not for all.
No you don't need coil overs. That's another post. Are you going to lower your car? Get 17X7 wheels if all possible. Most are 17X7.5. But 17X7 will give you more room to avoid rub.
With 17s, I recommend H&R OE Sport at .75 drop. I would go no lower than Sport Springs at 1.75/1.5. There will be some minor rub at certain situation. Again, it depends on what you are willing to live with as a trade off.
Thanks 2K2CivicEx!! As for the comment from 94GSRRacer2.... U can go suck a fat **** u gay *** Fuc* Nice contribution to the post. You just talk trash about people. You prolly dont know jack sheit. Just want to look like you know everything. If you going to talk about poeple.... back it up with some useful info. Dont just talk trash cuz that proves to me and everyone else you dont know anything. Thanks for the back up KAMiN. And everyone else who had some useful info... thank you!
sporty240
23
Aug 25, 2005 06:25 AM
JoshuaVTEC
11
Jul 8, 2003 01:06 AM
