Reconnecting power steering eqipment
Ok, I had a friend do some engine work and he disconnected my power steering, what are the steps to reconnect it?
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
what did he disconnect? the pump, lines, or just the belt? more info please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle »</TD></TR><TR><TD CLASS="quote">yeah it might be as simple as putting a belt back on. did he give you anything that he took off or what?
ok he took off the pump, bracket and belt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HTn00b »</TD></TR><TR><TD CLASS="quote">
ok he took off the pump, bracket and belt</TD></TR></TABLE>
it should go on the outtermost part of the crank. when you line up the pump back on the bracket theres really only one slot the belt will run off on the crank.
the belt should go on the outter part of the pulley, at least thats how mine was (inside one-alternator, middle one-a/c, outter one-power steering)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kruzen510 »</TD></TR><TR><TD CLASS="quote">the belt should go on the outter part of the pulley, at least thats how mine was (inside one-alternator, middle one-a/c, outter one-power steering)</TD></TR></TABLE>
cool, another piece of info I need is a pic of the engine showing how the ps bracket is placed
cool, another piece of info I need is a pic of the engine showing how the ps bracket is placed</TD></TR></TABLE>
Why not just have your friend reinstall everything? Or buy a repair manual? It's really not difficult to install. Look at the parts, and it should be pretty obvious how and where they go.
Oh, and there's no need to "bump" your thread every 10 minutes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Why not just have your friend reinstall everything? Or buy a repair manual? It's really not difficult to install. Look at the parts, and it should be pretty obvious how and where they go.
Oh, and there's no need to "bump" your thread every 10 minutes. </TD></TR></TABLE>
ok I just finished installing it, how tight do your turn the wing nut for the belt?
bumthology
Apr 18, 2019 02:29 AM
turbotime
May 27, 2006 04:54 PM
