who has ran 11.5:1 pistons in a b16a?
Old Dec 1, 2006 | 07:59 AM
palmeref9's Avatar
Default who has ran 11.5:1 pistons in a b16a?
just seenin the pros and cons about going bigger compression
Old Dec 1, 2006 | 08:47 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: who has ran 11.5:1 pistons in a b16a? (palmeref9)
11.5 is nothing crazy
I think my b16a was around 11.3 with a milled head (.020) and I daily drove it for a while.
Old Dec 1, 2006 | 10:42 AM
palmeref9's Avatar
any one else
Old Dec 1, 2006 | 10:47 AM
Natural Aspirations's Avatar
What are you using to increse your compression?
Old Dec 1, 2006 | 11:01 AM
palmeref9's Avatar
i was thinking of just swapping out the piston (je)and another quick ques u guys think i could use stock rods or is the compression going to be too much for it (by the way its the sir 2 b16a) any info would good thanx
Old Dec 1, 2006 | 11:06 AM
Default Re: (palmeref9)
What I would do. I would just mill the head, keep it under .040" and you should be good with your stock pistons. Does the motor need rebuilt? Unless you really want to drop a ton of cash on a B16 I would stick with OEM parts.
Old Dec 1, 2006 | 11:07 AM
What are you lookign to get out of your motor? If your a beginer I say read up and borrow an OMNI video from someone.
Old Dec 1, 2006 | 11:48 AM
palmeref9's Avatar
motor is just chillin in my garage i not a noob i want to get some opinions. the thing is with milling the head is that it can warp over time and valve clearance changes its a good opition. but i rather change the pistons and valvetrain, and shoot for 180-200 hp.
Old Dec 1, 2006 | 11:51 AM
palmeref9's Avatar
hell i might even go with ctr pistons and shaved the rods but i think i could get more with a aftermarket stuff and i want the engine to be reliable(daily driver, weekend warrior)
sleeperb16a
Feb 17, 2005 08:40 AM
ls_vtec_crx
Dec 17, 2003 03:01 PM
Red Civic T
Dec 18, 2001 06:57 AM
2latev8
Oct 27, 2001 11:29 PM
