Fluctuating idle
Old Nov 30, 2006 | 01:41 PM
ThaCivicAssassin's Avatar
Default Fluctuating idle
This all started when I disconnected my battery and recharged it. My car drives perfectly normal but I know I need a new battery. Sometimes when I'm done driving I put it in park and the idle fluctuates in waves. The rpm literally goes up and down like when the vacm hose is off. But the other day I started my car it did this and turned off. I checked for vacum leaks already. What could be the cause?
Old Nov 30, 2006 | 01:50 PM
redlsvtec4door's Avatar
Default Re: Fluctuating idle (ThaCivicAssassin)
how much does it go up or down. if it goes up to 2.5 k and then back down. try cleaning or replacing your iacv. if its only alittle adjust your idle with the screw on top of the tb
Old Nov 30, 2006 | 01:55 PM
Default Re: Fluctuating idle (redlsvtec4door)
ok.....ill check that
Kindled Light
32
Mar 1, 2019 06:06 PM
bk7794
20
Aug 7, 2016 02:59 PM
jdm_prelude19
Apr 4, 2011 05:58 PM
boostcrx89
Jan 13, 2008 07:04 PM
Norcalstoppy
Oct 7, 2002 10:47 AM
