My sweet winter beater, but with an issue.
Old Nov 29, 2006 | 07:27 PM
ef`rolla's Avatar
Default My sweet winter beater, but with an issue.
$100. 5 spd. Sun roof. and a sweet TENZO SHIFT **** OMGZ!11!~!!
only thing wrong is the damn thing doesn't blow warm heat, its kinda luke warm, if that. Help?
Old Nov 29, 2006 | 07:29 PM
WhiteBB2's Avatar
Default Re: My sweet winter beater, but with an issue. (ef`rolla)
haha def a beater
goodluck with the heat
Old Nov 29, 2006 | 07:40 PM
russlan44's Avatar
Default Re: My sweet winter beater, but with an issue. (WhiteBB2)
if i was u i would fix the heater
Old Nov 29, 2006 | 07:58 PM
ef`rolla's Avatar
Yea, it's in good condition, I'll slap some slipstreams on
Old Nov 29, 2006 | 08:01 PM
mgags7's Avatar
check the valve to the heater core, make sure the cable is soundly attached and that the valve opens and closes smoothly...
then check to make sure that the core isn't leaking out all the nice, hot coolant....
Old Nov 29, 2006 | 08:02 PM
M2B4's Avatar
Default Re: (ef`rolla)
lol have fun good to see another luder at it again.
Old Nov 29, 2006 | 08:03 PM
InvaderTrax's Avatar
Cheaper and in better shape then my winter car. Wish I could have found one
Old Nov 29, 2006 | 08:08 PM
prelude_h22vtec's Avatar
we hardly have winter here...its still warm here. otherwise i'd be driving a camry during the cold season. anyway make sure you even have coolant in there!
Old Nov 29, 2006 | 08:10 PM
mgags7's Avatar
lol no kidding....shorts, tshirt, and windows down tonight....lol
Rosko's Avatar
Default Re: (InvaderTrax)
I vote its the thermostat, its prolly stuck open and not letting the motor warm up.
not a bad way to spend $100
Old Nov 29, 2006 | 08:16 PM
CGags13's Avatar
damn son snow already??where are u located??...
100 bucks..nice score...turn it into a rally lude...yea def check that the lever is working correctly
Old Nov 30, 2006 | 05:12 AM
PirateMcFred's Avatar
You did better than I did. I got my 4th gen for $150 and the engine was blown. tires were good though.
Check the lever and the valve on the coolant hose to the heater core.
Pirate
Old Nov 30, 2006 | 07:07 PM
ef`rolla's Avatar
The recirc button was sticky and pushed, and I didn't realize till today, so now she blows a bit of warm air, but not warm enough, so I think that t-stat is stuck open.
Plans are to install a gauge pod w/ oil pres & water temp, remove the seats, remove the rears, lay down 1 big strip of black carpet, and keep it a 2 seater, remove the power steering pump etc. It's gonna be a fun car in the summer.
And I'm located in Saskatchewan Canada, the amount of snow seen in the pics accumulated in over 24 hours
Old Nov 30, 2006 | 07:08 PM
M2B4's Avatar
lol i bet. good luck. my project car was alot higher lol i paid 2g for my white 4th gen.
Old Nov 30, 2006 | 08:29 PM
yOnKiNaToR's Avatar
Default Re: (M2B4)
check your coolant too. i once didn't change the coolant in my car for at least 7 years and because of that, the coolant was brown sludge and it didn't produce hardly any heat.
Old Dec 1, 2006 | 05:03 AM
Jagan'92's Avatar
excellent beaten car. beater car I mean.
mrspeedy69
13
Nov 19, 2009 06:30 AM
724chris
Nov 19, 2009 12:11 AM
95si_v-tec
Nov 7, 2007 12:06 PM
ppl talk bout my old name
Dec 21, 2005 02:15 PM
Myroslav
May 9, 2005 02:38 PM
