Dizzy leak HELP
Old Nov 28, 2006 | 06:07 PM
hondachris1994's Avatar
Default Dizzy leak HELP
replaced the oring in the dizzy and still leaks, and yes I cleaned the area and its clearly comin from the dizzy
Old Nov 29, 2006 | 03:19 PM
bump
Old Nov 29, 2006 | 03:24 PM
ilovemysedan's Avatar
Default Re: Dizzy leak HELP (hondachris1994)
the problem may not be the seal... but what it is sealing to like the metal? i would check the metal for any gouging and or scrapes that would prevent it from sealing.
Old Nov 29, 2006 | 03:45 PM
Crx Jimmy's Avatar
does the dizzy make any noise if so the shaft could be worn and leaking oil thru the dizzy
Old Nov 29, 2006 | 03:53 PM
Default Re: Dizzy leak HELP (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">does the dizzy make any noise if so the shaft could be worn and leaking oil thru the dizzy</TD></TR></TABLE>no, Do u think I could try some RTV sealent around the shaft on the dizzy?
Old Nov 29, 2006 | 05:03 PM
anyone else have this problem?
Old Nov 29, 2006 | 05:06 PM
deadline's Avatar
pics would be helpful......
Old Dec 3, 2006 | 12:59 PM
Default Re: (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline &raquo;</TD></TR><TR><TD CLASS="quote">pics would be helpful......</TD></TR></TABLE>its the typical leakin all over the tranny, I took the dizzy off and u can clearly see where its leakin, its almost like its not fully meeting with the cylinder head, Its a MSD dizzy BTW, started leakin after a cpl days after I got it
Old Dec 3, 2006 | 02:15 PM
toolow69's Avatar
Default Re: (hondachris1994)
im having the same problem, i think im gona try some rtv on it
Ha Itz
Jan 2, 2007 05:57 PM
pythoner
Dec 7, 2006 10:47 AM
movingIIshadow
May 23, 2006 11:56 PM
b18cEF9
Apr 18, 2004 11:21 PM
TooDrunk2See
Oct 1, 2003 09:25 AM
