Dizzy leak HELP
replaced the oring in the dizzy and still leaks, and yes I cleaned the area and its clearly comin from the dizzy
bump
Re: Dizzy leak HELP (hondachris1994)
the problem may not be the seal... but what it is sealing to like the metal? i would check the metal for any gouging and or scrapes that would prevent it from sealing.
does the dizzy make any noise if so the shaft could be worn and leaking oil thru the dizzy
Re: Dizzy leak HELP (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">does the dizzy make any noise if so the shaft could be worn and leaking oil thru the dizzy</TD></TR></TABLE>no, Do u think I could try some RTV sealent around the shaft on the dizzy?
anyone else have this problem?
pics would be helpful......
Re: (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline »</TD></TR><TR><TD CLASS="quote">pics would be helpful......</TD></TR></TABLE>its the typical leakin all over the tranny, I took the dizzy off and u can clearly see where its leakin, its almost like its not fully meeting with the cylinder head, Its a MSD dizzy BTW, started leakin after a cpl days after I got it
Re: (hondachris1994)
im having the same problem, i think im gona try some rtv on it
