NEED HELP JUST GOT TURBO KIT IN
Old Nov 28, 2006 | 02:35 PM
JWHATCH23's Avatar
Default NEED HELP JUST GOT TURBO KIT IN
my turbo kit finally came in and i was wondering if my skunk 2 exhaust would fit and another thing my friend just blew his dc4 up and it was turbo and ecu is already tuned with chrome has 450cc injectors i think there obd0 injecters cause he had to use resistors and clips off of a DA i have the same engine b18b is the injectors and ecu already tuned worth 225 and can i run my car like this till i can get a walbro fuel pump and do you have to drop the tank on a dc4 for the fuel pump
Old Nov 28, 2006 | 04:56 PM
platinum00's Avatar
Default Re: NEED HELP JUST GOT TURBO KIT IN (JWHATCH23)
depends on your downpipe if you exhaust will fit. if not just go to a muffler shop and have them make you a section to mate them up
do not run your friens "tuned" ecu. every setup is different and you need to tune it yourself. you might want to by the ecu since it has chrome, but dont think you dont need to tune your car.
platinum.
Old Nov 29, 2006 | 08:44 PM
JWHATCH23's Avatar
would i have to tune it right away or could i wait a few weeks and about the fuel pump do i have to drop the tank
Old Nov 29, 2006 | 08:58 PM
mra4886's Avatar
shouldnt have to drop the tank most hondas if not all have it under rear seat
Old Nov 29, 2006 | 09:00 PM
TurboedDC's Avatar
like platinum00 said you will need to tune it your self (right away). Every turbo setup is different.
As far as i can till, you just have to pull the back seat out and get to the fuel pump access panle. So i dont think you have to drop the tank. . . . .
Old Nov 29, 2006 | 10:36 PM
HiProfile's Avatar
Default Re: NEED HELP JUST GOT TURBO KIT IN (TurboedDC)
For gods sake man, try making your posts more like a teenage girl - pepper them with regular periods!
If you're asking this info w/o even knowing about saturated and peak/hold injectors, I'd say you're in a world of hurt unless you let a pro go at it for you. And FYI, stock pumps are capible of handling 450cc injectors if you don't medle with the pressure. After that, upping the pressure doesn't add much fuel flow as bigger injectors can.
I'd suggest taking what you can of his, then let a crome tuner alter the chip accordingly.
EG-SIXV-TEC
Jun 14, 2012 12:33 PM
range hadies
Apr 4, 2012 01:25 PM
nthao89
10
Dec 17, 2008 09:49 PM
jonnyboo
17
Oct 19, 2007 09:10 PM
Teluan
Aug 29, 2001 09:04 PM
