Another "weird noise" thread...
Old Nov 28, 2006 | 02:34 PM
GtechPro's Avatar
Default Another "weird noise" thread...
It's hard to explain what it sounds like, but I'll do my best....
This sound kinda reminds me of a tire with a big nail in it, or better yet a screw with a large head as it's hitting the pavement. It's coming from the right front side of the car. It can be heard once per wheel rotation.
I took the wheel off, examined the tire (about a couple of weeks old) and found nothing. Clean as a bean.
I made sure that nothing is rubbing, I also checked the axle and pretty much everything else on that side of the car. Everything seems to be ok. Car runs fine, alignment is fine, brakes are fine, but the noise is there.
As a kid, I used to attach a piece of a plastic cup to the front fork of my bike and it would make this cool flapping sound as the wheel hit it. Weird, i know.
But it was a cool thing to do back then, and if you've done it then you'll know exactly what I'm talking about. It sounds just like that!
I'm running out of things to inspect, and I just can't figure out what it is... It's very annoying to say the least...
Any input will be appreciated.
Old Nov 28, 2006 | 02:37 PM
E-Money's Avatar
Default Re: Another "weird noise" thread... (GtechPro)
balanced?
Old Nov 28, 2006 | 02:42 PM
CGags13's Avatar
Default Re: Another "weird noise" thread... (E-Money)
is the wheel rubbing against anything...how about the brake rotors??
Old Nov 28, 2006 | 04:15 PM
. a d a m's Avatar
is there a wobble? Did you check your wheel bearings?
Old Nov 28, 2006 | 04:19 PM
astrophillio's Avatar
I've had a similar problem, but it was on my driver side. It turned out to be the wheel bearing, which costs about $250 to fix at Honda. If it is the wheel bearing then you should fix it asap because its dangerous....basically your wheel will start wobbling and could possibly fall off if left unfixed.
Old Nov 29, 2006 | 02:32 AM
AdReNaLiN's Avatar
Wow! I have this exact same problem...
Its like a ticking/tapping sound as you go around a corner - in particular roundabouts.
Mine is also from the right front...
Old Nov 29, 2006 | 05:35 AM
Lewdin' Incognito's Avatar
Default Re: (AdReNaLiN)
CV joint, wheel bearing, ball joint, brakes/rotors are all things I would look at.
Old Nov 29, 2006 | 07:07 AM
mgags7's Avatar
Shounds like a wheel bearing to me sir....jack up tha corner and try to jiggle the wheel around laterally and vertically without having the steering wheel move at all.....if it jiggles more than just a tiny bit, that is a bad wheel bearing, which could be binding and making that sound....
Also, check out the abs sensor, make sure there is nothing caught in there....
Old Nov 29, 2006 | 07:48 AM
GtechPro's Avatar
Default Re: (bb4ever)
Balanced - yes (a couple of weeks ago)
Wobble - none
Rubbing - none
CV joints - good
brakes/rotors - good
I did check the wheel bearing and it seems to be fine.
Like I said, I checked everything on that side. I'm clueless. Now I'm thinking about having the tire inspected. Maybe it's a factory defect... That noise did start at about the same time I put my new wheels/tires on, or a couple of days later. I really can't think of anything else to check, so keep them suggestions coming
Old Nov 29, 2006 | 12:47 PM
mgags7's Avatar
The belt in the tire could be shifted, which makes a noise much like I believe you are describing....that can happen either as a factory defect or after slamming a pothole or something like that...
Old Nov 29, 2006 | 12:49 PM
Switch tires and see if noise follows that one.
Old Nov 29, 2006 | 12:51 PM
mgags7's Avatar
^^great idea
Old Nov 29, 2006 | 01:52 PM
. a d a m's Avatar
Default Re: (Lewdin' Incognito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewdin’ Incognito &raquo;</TD></TR><TR><TD CLASS="quote">CV joint, wheel bearing, ball joint, brakes/rotors are all things I would look at.</TD></TR></TABLE>
CV joint is more of a knocking sound almost, you'll definitely notice when they go bad because its LOUD.
Have the tires checked out, I assumed you at least looked at the tie rod end?
Old Nov 29, 2006 | 02:02 PM
GtechPro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">The belt in the tire could be shifted, which makes a noise much like I believe you are describing....that can happen either as a factory defect or after slamming a pothole or something like that...</TD></TR></TABLE>
That's my last guess... I checked everything I could possibly think of, and then some...
I'll switch the tires around to see what happens.
Thanks guys
Old Nov 29, 2006 | 02:13 PM
roller3804's Avatar
Default Re: (GtechPro)
one last thing to look at. It could be the splash guard under the fender catching the tire and kind of clicking. But thats only if your dropped.
swabby
Honda Civic (2006 - 2015)
12
Aug 23, 2006 08:40 AM
carbonlaced
Jun 27, 2006 10:02 AM
Everyones Hero
Feb 11, 2006 08:27 PM
bpetruzzo
11
Aug 20, 2005 02:54 PM
NyTrYdEr AcCoRd
Nov 23, 2003 08:55 PM
