my car wont shut off
Old Nov 28, 2006 | 10:20 AM
honda13typer's Avatar
Default my car wont shut off
i swapped my d15 out of my daily driver for a d16z6 and now my car wont shut off i have to unplug my wiring harness to shut off my car...from my searched it looked like my ignition switch went bad so i swapped it for a working one and it still deosnt turn off...not sure what else it could be....any ideas?
also my car is completly stock and i dont have an alarm
Old Nov 28, 2006 | 10:26 AM
sasser43's Avatar
Default Re: my car wont shut off (honda13typer)
Can you turn the keys to the off position and take them out?
Old Nov 28, 2006 | 10:31 AM
Default Re: my car wont shut off (sasser43)
yea i can pull the key out and the car stay on...if the battery is connected the gauge lights stay on as if the key was in there even though its not...
Old Nov 28, 2006 | 10:33 AM
NonovUrbizniz's Avatar
Loved
Your ECU is most likely getting constant power instead of ignition power.
Old Nov 28, 2006 | 10:36 AM
Azn Kenny's Avatar
What a neat trick.
Old Nov 28, 2006 | 10:47 AM
killakoupe's Avatar
From: San Diego to Palm Springs Runnin Things, CA, USA
Default Re: (Azn Kenny)
craaaaaaaazy...
wish i could give you helpful info, but cant
but thats crasay.
goodluck th0
Old Nov 28, 2006 | 10:50 AM
instrument's Avatar
is it a stick or auto?
if its a stick just put it in gear and dump the clutch, it'll stall and turn off.
now for a permanent fix you'll have to ask someone else.
Old Nov 28, 2006 | 11:04 AM
Default Re: (instrument)
its 5speed but i can get it to turn off by unplugging a harness but i need a permanent fix...
Old Nov 28, 2006 | 11:26 AM
FalkenSiR's Avatar
Default Re: (honda13typer)
stall it but make sure no one sees you
Old Dec 2, 2006 | 08:19 AM
Loved
Did you check if the ECU is getting constant power instead of ignition power?
Old Dec 2, 2006 | 12:56 PM
Default Re: (NonovUrbizniz)
how exactly do i check that?
Old Dec 2, 2006 | 01:03 PM
platinumx6's Avatar
Does it run perfect or does it sputter and barely turn over? My rex did that occasionaly.
Old Dec 2, 2006 | 03:39 PM
Default Re: (platinumx6)
the car runs smooth..finally fixed the car!!! after looking over everything changeing main relay ignition relay nothing work then as i was giving up i decided to look behind the guage cluster and as i unscrewed it the light went off and the car went back to normal...i looked behind the cluster didnt find anything wrong maybe something was pinched i dunno the car just seemed to fix itself....weird
Old Dec 2, 2006 | 08:36 PM
Loved
If I were you I wouldn't drive the car till you find the problem...
It most likely was a pinched wire in the cluster... BUT... that means that you've broken through the plastic coating on at least 2 wires... I would take it apart and inspect everything closely... A constant power wire crossing with ANYTHING is begging for a fire...
Especially considering whatever power source you're dealing with obviously isn't popping a fuse when it crosses with whatever other line it's crossing with.
You would check constant power to the ECU by checking the power connection to the ECU with a test light or multimeter... check it first with the car off and the key out of the ignition... and then again with the key turned to "accessory"
You need a wiring diagram though because there is probobly at least one constant power to the ecu normally... but one of them obviously is only supposed to come on with ignition.
Old Dec 3, 2006 | 12:08 AM
yea im gonna give it a good look over tomorrow err techinacally today....
Freeclowns
14
Feb 28, 2013 09:20 PM
Bad_dude
Audio / Security / Video
Aug 10, 2012 08:00 PM
siblues
10
Mar 11, 2010 11:55 AM
xpl!cit
Dec 29, 2006 03:25 PM
honda13typer
Nov 28, 2006 12:23 PM
