H.I.D Plug and play
H.I.D Plug and play
I'm sorry I'm cheap, but humor me. I bought a plug and play H.I.D kit, I'm sure many others have too so does one know any tricks on how to get rid of some of the glare besides retrofitting? Thanks
HT White Ops
Re: (jdmcivicb16a2sc61)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicb16a2sc61 »</TD></TR><TR><TD CLASS="quote">Thanks Eran, I have read some of your DIY before and thanks alot for all the good info, what are casper shields and can i buy them?</TD></TR></TABLE>
Casper shields are a rebasing for hid bulbs. I'm not sure if you can use them for your PnP kit, but here's where to get them. They call them H4 to D2R/D2S converters.
http://www.hidexpert.com/
H-T Poker champion
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
No, you cant use them on a plug and play kit because it's already an H4 based bulb. However, you can simply cut a coke can into a shield and secure it to the base of the bulb. You would want the shield to be on the bottom side of the bulb, so it cuts off light from going to the bottom of your headlight housing and reflecting back up. You can make it as long as you like.. I'd recommend making it longer than shorter [you can even make it go all the way to the headlight glass/plastic if you want].
Just look at the casper shields and model the shield after that..
Just an idea. You'll still get some glare, but not nearly as bad.
Re: (Hatchy-Ownzjo0)
how much did the kit cost? 250-350 around that? you could have done an cheap retro for around 300 but ur cutoff line wouldnt look that great. But u would have reduced ur glare a **** load..
Re: (Thizzed Out)
Yea, it was the Bi-xenon kit for $190, question how in the crap do I get a shield in the housing, doesn't Honda glue them shut? when you say make a shield do you mean like this guy? http://www.suvlights.com/infor...id=32
Modified by jdmcivicb16a2sc61 at 11:55 PM 12/2/2006
Re: H.I.D Plug and play (nighttrain33)
why do ppl even post if they are not gonna answer the question, why waste everyone time and post the search, loose your self, if you dont know then post that, dont just do what everyone else does, be a leader not a follower
Re: H.I.D Plug and play (1DA2NV)
huh?! leader not a follower?! dude hes only talking about hid's... and why r u posting since u didnt answer the question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1DA2NV »</TD></TR><TR><TD CLASS="quote">why do ppl even post if they are not gonna answer the question, why waste everyone time and post the search, loose your self, if you dont know then post that, dont just do what everyone else does, be a leader not a follower</TD></TR></TABLE>
itr-j
06-13-2002 08:40 AM
