Ignition Start Problem
Old Dec 29, 2006 | 10:52 AM
xpl!cit's Avatar
Default Ignition Start Problem
I tried looking in all the articles and did a search but nothing quite seemed to describe my problem. Basically, there are three positions for the key to turn in the ignition cylinder: 0, 1 (all dash lights on), 2 (to start the car). I have no problems starting my car so I know it's not the starter, I have power to all systems so I know the battery is not dead but after I start the car (position 2 -> 1) the car dies completely.
The ignition cylinder is fine but for some reason, the key will return to the "resting" position (position 1 - when the car is normally running after starting) but quit as soon as it's in position 1.
I think the ignition harness or wiring loom connecting to the key cylinder has some dead leads or something because there is a "sweet spot" where I have power. Last night, I left the key in this position and pop the clutch to get the car going - no problems after that and the car ran fine.
I'm sorry if this doesn't make any sense but it's the best I can explain it. Any thoughts?
Old Dec 29, 2006 | 03:25 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Ignition Start Problem (xpl!cit)
ignition switch.....which is a multifunction switch that transfers the power immediately after turning the key in your cylinder.....one of the contacts probably is shitty or corroded
Derrick_12341
Jul 14, 2018 12:52 PM
exz0n-.-
Oct 23, 2008 04:57 PM
92TEGsrSC
Jun 18, 2003 09:15 PM
sharkey65a
Feb 15, 2003 03:53 PM
