No spark, no injecter pulse...
Old Nov 28, 2006 | 06:17 AM
rogue420's Avatar
Default No spark, no injecter pulse...
Working on a friends 95 ex and there is no spark or injector pulse. everything is plugged in. any ideas? cam sensor maybe?
Old Nov 28, 2006 | 06:46 AM
B16B_coupe's Avatar
HRD PKR
Default Re: No spark, no injecter pulse... (rogue420)
are spark plugs good? ignition coil good?
Old Nov 28, 2006 | 07:01 AM
streettuned's Avatar
Default Re: No spark, no injecter pulse... (B16B_coupe)
is the timing belt in tact, cam turning over with the crank?
Old Nov 28, 2006 | 07:04 AM
miahmouse's Avatar
main relay? ecu fuse (fie/m) engine bay, the one you pull to reset the ecu...
Old Nov 28, 2006 | 08:01 AM
cranny's Avatar
24.224.233.247
Default Re: No spark, no injecter pulse... (miahmouse)
if the timing belt is in tact , id say definitely the dizzy.
Old Nov 28, 2006 | 08:39 AM
rogue420's Avatar
Default Re: No spark, no injecter pulse... (cranny)
timing belt is intact, coil is good, cant get a code. got a new dizzy same ****.
Modified by rogue420 at 10:16 AM 11/28/2006
Old Nov 28, 2006 | 09:21 AM
B16B_coupe's Avatar
HRD PKR
is the car all stock?
Old Nov 28, 2006 | 09:24 AM
rogue420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">is the car all stock?</TD></TR></TABLE>
Yes, all stock.
Old Nov 28, 2006 | 09:36 AM
B16B_coupe's Avatar
HRD PKR
what all have u tried?
Old Nov 28, 2006 | 09:43 AM
rogue420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">what all have u tried?</TD></TR></TABLE>
Checked spark, checked pulse, inspected timing belt. checked coil, checked relays and fusable links, bought new dizzy(will return), don't have the conector to check codes on a honda so i tried to bridge and no flashy. checked to make sure everythings connected. car was dead when brought in.
Old Nov 29, 2006 | 05:52 AM
miahmouse's Avatar
If all that is good then I'd start to wonder about the ecu...
Old Nov 29, 2006 | 06:38 AM
rice a roni's Avatar
ecu...or fuse for ecu??
Old Nov 29, 2006 | 08:01 AM
jdeemseerx's Avatar
is the fuel pump priming? does the CEL come and then go out at Pos. 2? Im thinking either bad ECU or Main Relay
Old Jul 2, 2007 | 06:19 PM
B18EG6's Avatar
Default Re: (jdeemseerx)
I am having the same problem
NEW distributor
ECU confirmed to work in friend's car just fine
NEW starter
NEW plugs
Able to datalog info from the ECU so I know it can see the motor. Also, checked for continuity on several lines and found no problems
NO injector pulse, just a drop in battery voltage.
Screenshots, wiring, and oscilloscope readings in this thread
https://honda-tech.com/zerothread?id=2029190
Thanks
seb
Old Jul 2, 2007 | 06:35 PM
pakman89's Avatar
check your grounds and check the ground on the thermostat housing make sure its not loose or rusted
Old Jul 2, 2007 | 06:38 PM
B18EG6's Avatar
Default Re: (pakman89)
Thanks for the reply
I have 4ga wire grounding the cylinder head and transmission to bare metal on the chassis. New hardware was used, and copper lugs were soldered on without using flux.
My thermostat ground was cleaned off with a file and a new bolt was used there also.
The pump primes and there is pressure in the rail
Kt18777
Apr 3, 2014 09:36 PM
exit22lsv
20
Nov 5, 2008 07:11 AM
lsvtek
May 11, 2008 11:06 PM
Powered by VTEC
Jan 25, 2008 01:05 PM
Dropped90Integra
Jan 21, 2006 09:24 AM
