CTR shift boot
Old Nov 27, 2006 | 08:14 PM
mr_nemesis2003's Avatar
Default CTR shift boot
Hey, what's up guys, the problem of the week is that i installed a OEM CTR shift boot and now the stock shifter won't fit. I could force it in, but i think that the little ring on top might break. Any suggestions? Right now i am using a ITR replica shift ****, that's the only other **** i can use that i have. Also, do you guys think a si or ls/gsr shift **** will fit withouth breaking the plastic ring?
Old Nov 27, 2006 | 08:16 PM
dohcVTECeg2's Avatar
Default Re: CTR shift boot (mr_nemesis2003)
its not supposed to go down all the way on the shifter. just push it down far enough so that the hard plastic ring doesnt break
Old Nov 27, 2006 | 08:30 PM
If i put it to the point where it touches the ring it still feels loose.
Old Nov 27, 2006 | 08:35 PM
Eran's Avatar
HT White Ops
A CTR boot won't work with the CX/DX/LX/EX shift ****. Not sure about an Si ****, but I know a GS-R leather works.
Old Nov 27, 2006 | 08:39 PM
turnsignalandy's Avatar
Default Re: (Eran)
will a skunk2 or blox work?
Eran's Avatar
HT White Ops
Default Re: (turnsignalandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">will a skunk2 or blox work?</TD></TR></TABLE>
Of course. They're Type-R knockoffs.
Old Nov 27, 2006 | 08:58 PM
Default Re: (Eran)
would it work with an old style mugen shift ****? The tall and skinny one?
Old Nov 27, 2006 | 09:09 PM
So for sure a gsr leather will fit? If so any one got hook-ups in the socal area in a Acura dealership? The gsr one looks comfortable.
Old Nov 27, 2006 | 09:39 PM
Eran's Avatar
HT White Ops
A CTR boot will accommodate most aftermarket shift *****. The only problem is how deeply countersunk the oem **** is.
Also, if you're **** like me and hate that look of the shift boot sagging when you have a type r or type r-style **** (ie, skunk2, blox, etc), you can use two neoprene rubber washers (available for all of $0.10 each at a hardware store) on the shifter arm, and then install the shift boot over it.
Old Nov 27, 2006 | 09:54 PM
Cool, thanks for the tip, i used to put tape in shifter arm in order to make it hold, a lil ghetto, but it got the job done, well, atleast is used black electric tape so no one could see it. Also, would any one know where to get the bolt that comes w/ the itr shift ****, i'm guessing a hardware store, but what size.
MIKEuBEEZY
Jul 1, 2008 01:33 AM
RedSix
Jan 6, 2008 08:10 AM
K.RigSeg
Jun 5, 2004 05:29 PM
eg64u
Feb 14, 2004 06:40 PM
EricUSC
Mar 15, 2003 08:45 PM
