I need help with my acura
Hi, I have an acura gs b18 motor, wiseco forged pistons low compresion 9:5, eagle connecting rods, block guard, xs turbo kit with garret turbine to3 to4 for 11 pounds of boost, 330 inyectors, fuel regulator and rail, external bosh bomb of 125 psi, original computer. the car run with a escape temperature(pyrometer) from 11 to 14, I understand that this temperature is high. What can Ido to lower this temperature from 7 to 10 or the adecquate one? are fine the actual inyectors or should I change them? Thanks pedro from puerto rico
its either too rich or too lean! thats why its running that hot. normal cruising temps should be at 600-800 and at redline 1200-1300, but the temps will drop fast,
Got_EF8
13
Feb 17, 2006 08:02 AM
Joel_MN
Aug 29, 2003 11:58 AM
