Full Race/Laskey Racing built Civic Si........540hp, 344lb/ft
Old Nov 27, 2006 | 09:14 AM
B20VTI's Avatar
Default Full Race/Laskey Racing built Civic Si........540hp, 344lb/ft
Dyno Print out -
Motor Spec -
Benson sleeved 83mm B20 block
89mm Benson balanced and micropolished crank
CP 9-1 pistons/rings, Eagle 3/8 rods, ACL bearings
New OEM oil pump, new pick-up, new waterpump
ARP head studs and Cometic head gasket
New SuperTech valves, dual springs and titanium retainers
B16 VTEC head with 3 angle valve job, new seals, surfaced, all done by
PortFlow
CTR intake and exhaust cams, AEM 5 bolt cam gears
New STR fuel rail and new 1000cc RC Injectors
Edlebrock Victor X with stock throttle body, sensors and vtec selenoid
Oil pump adaptor with ls/vtec line in place
external coil plug and spark plugs
New timing belt, harmonic balancer
Driveshaft shop stage 3 driveshafts
SPA gauges
Motec M4 pro ECU
Full Race Stage 3 Pro-am Kit (top mount)
Built by Laskey Racing, tuned by Owen Developments
Pics will come shortly........
Old Nov 27, 2006 | 09:17 AM
DJ_SaNdOz's Avatar
Default Re: Full Race/Laskey Racing built Civic Si........540hp, 344lb/ft (B20VTI)
I am assuming that this is an all drag car based on the power curve?
Old Nov 27, 2006 | 09:20 AM
B20VTI's Avatar
Default Re: Full Race/Laskey Racing built Civic Si........540hp, 344lb/ft (DJ_SaNdOz)
Weekend driven and some dry evenings.
Over here in the UK the weather sucks so its hard trying to get traction in the rain
Old Nov 27, 2006 | 09:25 AM
miller's Avatar
something doesent look right.
what was your target boost?
it seems the boost came on very late but then was creeping the rest of the way??
BoostedEG6's Avatar
what turbo are you running?
Old Nov 27, 2006 | 09:29 AM
miller's Avatar
Default Re: Full Race/Laskey Racing built Civic Si........540hp, 344lb/ft (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">what turbo are you running?</TD></TR></TABLE>
should be the 67/p , thats what comes with the stage 3 kit
B20VTI's Avatar
Garrett T3/T67 HO
I doubt the boost is creeping, its all being monitered by the motec m4. The boost isnt moving.
Old Nov 27, 2006 | 09:30 AM
ShawnR's Avatar
im gessing this is on race gas?
Old Nov 27, 2006 | 09:31 AM
miller's Avatar
look at the graph, it dosent lie. peak tq. at 8000rpm??? something isnt right
Old Nov 27, 2006 | 09:35 AM
atun_fab_in_south_fl's Avatar
looks like the full boost come on 7500-8000
its big turbo, for this HP better smaller turbo and get power earlier
Old Nov 27, 2006 | 09:36 AM
BoostedEG6's Avatar
Default Re: Full Race/Laskey Racing built Civic Si........540hp, 344lb/ft (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">look at the graph, it dosent lie. peak tq. at 8000rpm??? something isnt right</TD></TR></TABLE>
Yeah I was going to say the same thing.... I have that turbo and I know that its not that laggy something seems to be wrong somewhere along the line
Old Nov 27, 2006 | 09:42 AM
Archidictus's Avatar
Unceasing Measure
When I saw that chart - before I read the build sheet - I figured it was a B16 with some funny tuning. That torque curve isn't right for an 89mm B20.
Old Nov 27, 2006 | 11:17 AM
Boner_Ben's Avatar
My b16 with the same turbo got full boost before 7k so something is off.
Old Nov 27, 2006 | 11:37 AM
B20VTI's Avatar
To be honest i have no idea, i love the way it drives though.
The turbo is an .82a/r. It was tuned on our pump gas so 98ron.
Old Nov 27, 2006 | 11:40 AM
BoostedEG6's Avatar
Default Re: (B20VTI)
if you like/happy with it then thats all that matters
Old Nov 27, 2006 | 11:49 AM
B20VTI's Avatar
Just means i have to rev it more, as its not used everyday its not much off a worry.
Just out of intrest what would cause it to make boost that late on??
Old Nov 27, 2006 | 01:11 PM
blundar's Avatar
Lines aren't crossing at 5250. Hmm. The low boost torque curve (flat 6000 - 9000?) doesnt cross any of the HP curves at 5250. High boost looks kinda ok.
Post a proper dyno graph and we might be able to help more. At a first glance, it looks like boost controller issues. Look at the slope of the line of the high boost torque compared to the low boost torque. The low boost torque is rising at a faster rate from 4500 - 5500 than the high boost torque. Also, the torque for pre-spool from 2000 to 5500 or so is radically different. Are you using a bang-bang style antilag? I'm going to guess that your low boost setting is somewhere in the 11-13psi range based on the T3/T67 cars I've tuned.
There are a lot of very weird things in your graph. I've played with the turbo you are using (T3/T67HO) on some of the older Full-Race kits and the boost curves / torque curves look very very very different than your high boost setting.
I'll shoot you a PM with a link to a dyno of a 81mm GSR w/ T3T67 for comparison purposes. I think you'll see what I mean.
Old Nov 27, 2006 | 02:12 PM
B20VTI's Avatar
Default Re: (blundar)
thanks man, il check it out.
Old Nov 27, 2006 | 02:44 PM
Mr HYDE's Avatar
wheres some pictures of the car and setup
Old Nov 27, 2006 | 07:41 PM
rex_racer728's Avatar
Default Re: (Mr. HYDE)
Wow good numbers on CTR Cams!! Congrats
Old Nov 28, 2006 | 12:59 AM
B20VTI's Avatar
Default Re: (rex_racer728)
Thanks for the in put, think some of you may be confused by the graph. Its not low boost and high boost plots. Its one boost figure of 1.17 bar. (16psi)
The lines represent Flywheel hp and torque, and wheel hp and torque.
- 540 @ flywheel hp which is 415 @ wheel hp
- 344.9 lbft @ flywheel which is 218 lbft @ wheels
Old Nov 28, 2006 | 04:20 AM
No-Gi's Avatar
Damn, that makes less sense. Power is very low IMO.
Old Nov 28, 2006 | 11:06 AM
slow poke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rex_racer728 &raquo;</TD></TR><TR><TD CLASS="quote">Wow good numbers on CTR Cams!!</TD></TR></TABLE>
Why would you say that? CTR cams are the ****
B20VTI
Oct 19, 2006 04:37 PM
B20VTI
May 25, 2006 10:29 PM
B18C5civic
Mar 14, 2006 10:46 AM
B18C5civic
Oct 20, 2005 11:58 PM
