B16a SWAP???
Old Nov 26, 2006 | 05:30 PM
Hatchman98's Avatar
Default B16a SWAP???
I did a b16a jdm motor swap (obd1) into a 98 EK hatch OBD2.... I have the throttle position sensor plugged in ... do i need the map sensor plugged in on top of the throttle body or just the tp sensor? (Motor is a 92-95 jdm del sol motor...)
Old Nov 26, 2006 | 05:36 PM
hondachris1994's Avatar
Default Re: B16a SWAP??? (Hatchman98)
you need them both plugged in
Old Nov 27, 2006 | 05:13 PM
Hatchman98's Avatar
Default Re: B16a SWAP??? (hondachris1994)
will the ecu read it at all.. bc stock , the motor does not come with it ..... so ur sayin i gotta get a newer one from like a gsr
Old Nov 27, 2006 | 05:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchman98 &raquo;</TD></TR><TR><TD CLASS="quote"> bc stock , the motor does not come with it </TD></TR></TABLE>u talkin bout map sensor?all motors have map sensors a tp sensors and yes the ecy will look for both of them
Old Nov 27, 2006 | 06:08 PM
Hatchman98's Avatar
ya a map sensor? The b16a jdm motor i have didnt come w. one just a tp sensor but the harness i have obd2 has a plug for one. so i need to get a newer throttle body like from a 98 gsr with the map sensor or can i run with just the tp sensor hooked up
Old Nov 27, 2006 | 06:38 PM
Im pretty sure your motor has a map sensor, your map sensor should have a hose runnin to the intake many if its not on your Throttlebody
Old Nov 28, 2006 | 04:43 PM
Hatchman98's Avatar
ya but shouldnt there be a plug as well or just a hose...? or na cuz its a older obd1 motor.
nuginu
K Series
Aug 17, 2013 11:26 AM
moemoney
Sep 7, 2011 10:33 AM
dkboyny11
Apr 26, 2007 04:46 PM
Brian Hinson
13
Jun 24, 2006 04:05 PM
