B16a SWAP???
B16a SWAP???
I did a b16a jdm motor swap (obd1) into a 98 EK hatch OBD2.... I have the throttle position sensor plugged in ... do i need the map sensor plugged in on top of the throttle body or just the tp sensor? (Motor is a 92-95 jdm del sol motor...)
Re: B16a SWAP??? (hondachris1994)
will the ecu read it at all.. bc stock , the motor does not come with it ..... so ur sayin i gotta get a newer one from like a gsr
Re: B16a SWAP??? (Hatchman98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchman98 »</TD></TR><TR><TD CLASS="quote"> bc stock , the motor does not come with it </TD></TR></TABLE>u talkin bout map sensor?all motors have map sensors a tp sensors and yes the ecy will look for both of them
ya a map sensor? The b16a jdm motor i have didnt come w. one just a tp sensor but the harness i have obd2 has a plug for one. so i need to get a newer throttle body like from a 98 gsr with the map sensor or can i run with just the tp sensor hooked up
Im pretty sure your motor has a map sensor, your map sensor should have a hose runnin to the intake many if its not on your Throttlebody
Brian Hinson
13
06-24-2006 04:05 PM
