water pump and oil pump
Old Nov 24, 2006 | 03:37 PM
CivicVX94's Avatar
Default water pump and oil pump
I'm piecing together an ls-t and figure i'll replace my stockand old water and oil pump.
i heard i can use an ITR water and oil pump on an ls w/ no problem.. this true?
next question, if that's true, can i still use a stock ls timing belt?
Thanks in advance for any help
Old Nov 24, 2006 | 03:41 PM
NA JDM GSR's Avatar
Default Re: water pump and oil pump (CivicVX94)
yes to all
Old Nov 24, 2006 | 04:29 PM
CivicVX94's Avatar
Default Re: water pump and oil pump (NA JDM GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA JDM GSR &raquo;</TD></TR><TR><TD CLASS="quote">yes to all</TD></TR></TABLE>
THanks
Old Nov 24, 2006 | 06:15 PM
Redline130's Avatar
I'm pretty sure you have to match the timing belt to the water pump being used. The LS and GSR/ITR water pumps have a different amount of teeth (19 vs. 22).
Old Nov 24, 2006 | 08:15 PM
NA JDM GSR's Avatar
Default Re: water pump and oil pump (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure you have to match the timing belt to the water pump being used. The LS and GSR/ITR water pumps have a different amount of teeth (19 vs. 22).</TD></TR></TABLE>
ls and gsr/itr belts are the same
Old Nov 25, 2006 | 12:04 PM
frostyrb's Avatar
B16a is also the same for the oil & water pump, incase it is easier to go to honda then acura.
Old Nov 25, 2006 | 12:44 PM
DonF's Avatar
GSR/R timing belts have 1 more tooth than an LS. You match the belt to the water pump.
Old Nov 26, 2006 | 09:24 PM
CivicVX94's Avatar
Default Re: water pump and oil pump (DonF)
theres alot of dif. stuff being said, so can we get this straight<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">GSR/R timing belts have 1 more tooth than an LS. You match the belt to the water pump.</TD></TR></TABLE>or<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA JDM GSR &raquo;</TD></TR><TR><TD CLASS="quote">
ls and gsr/itr belts are the same</TD></TR></TABLE>do all the water pumps have the same number of teeth or different? and if they're dif. this holds for the belts too i guess, so what's right?
and <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frostyrb &raquo;</TD></TR><TR><TD CLASS="quote">B16a is also the same for the oil & water pump, incase it is easier to go to honda then acura.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">GSR/R timing belts have 1 more tooth than an LS. You match the belt to the water pump.</TD></TR></TABLE>
so does the b16 have the same # of teeth as the gsr/r or as the ls?
THanks for all the replies, now lets try to set this stuff straigh so misinformation/interuptation is getting passed around
Old Nov 26, 2006 | 11:43 PM
Redline130's Avatar
https://honda-tech.com/zerothread?id=1818346
I know for sure that Meziere who makes a B-series electric water pump kit offers a model with 19 teeth for LS motors and one with 22 teeth for DOHC VTEC motors. Like I said before, you have to match the water pump to the timing belt being used. Also, B16 water pumps and oil pumps are the same as other DOHC VTEC B-series water and oil pumps.
Old Nov 27, 2006 | 12:04 AM
turbod da's Avatar
whatever w/pump u use u have to use same t/belt EXECPT!! the b16 b/c the block is shorter thus t/belt is not as long,, b18 blocks r taller..... easy way to do it gsr everthing oil pump dont matter u could use any but i use vtec { gsr } 4 better oil flow.
Old Nov 27, 2006 | 05:45 PM
CivicVX94's Avatar
Default Re: water pump and oil pump (SNACH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SNACH &raquo;</TD></TR><TR><TD CLASS="quote">whatever w/pump u use u have to use same t/belt EXECPT!! the b16 b/c the block is shorter thus t/belt is not as long,, b18 blocks r taller..... easy way to do it gsr everthing oil pump dont matter u could use any but i use vtec { gsr } 4 better oil flow.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1818346
I know for sure that Meziere who makes a B-series electric water pump kit offers a model with 19 teeth for LS motors and one with 22 teeth for DOHC VTEC motors. Like I said before, you have to match the water pump to the timing belt being used. Also, B16 water pumps and oil pumps are the same as other DOHC VTEC B-series water and oil pumps.</TD></TR></TABLE>
Hell ya thanks alot for your help
Just a recap...
All B series vtec water pumps and oil pumps are the same and have the same # number of teeth (22) and you choose the timing belt based on the water pump. the exception being if you have a b16 water pump, then you use a gsr/r timing belt, due to the b16 having a shorter block.
soon2bdropped
Jul 22, 2007 11:33 AM
kobeRy_si
Jun 6, 2005 03:11 PM
rafiq7
Nov 2, 2004 11:41 AM
jDMJeRk
Jan 27, 2004 10:45 AM
thaiphob
Oct 31, 2003 05:24 AM
