water pump? differences?
Old Oct 30, 2003 | 11:47 PM
thaiphob's Avatar
Nikon!!!
Default water pump? differences?
im gonna be changing my timing belt pretty soon, and might as well change my water pump while i have it out. just wondering if it would benifit me to use a gsr or type r water pump versus a regular Ls water pump?
Old Oct 31, 2003 | 12:55 AM
riceball777's Avatar
Default Re: water pump? differences? (thaiphob)
gsr water pump is better than the ls one
but if use the gsr or itr water pump you have to use the gsr or itr timing belt too
i'm useing the itr timingbelt and water pump in my lsvtec
Old Oct 31, 2003 | 05:24 AM
arw321's Avatar
Default Re: water pump? differences? (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">gsr water pump is better than the ls one
Wrong.
It all depends on the application. The LS gear has 19 teeth compared to the GSR/vtec gear which has 22 teeth. If you are going to be revving high (ie 8,000 rpm) on a regular basis, use the gsr pump. If not, stick with the LS. The gsr pump has a lower flow rate because of the extra 3 teeth on the gear, and will therefore flow coolant through your motor at a slower rate, and theoretically will increase cooling capacity (coolant has more time to pick up the heat generated by your motor).
HTH.
soon2bdropped
Jul 22, 2007 11:33 AM
19sec beast
Mar 31, 2006 04:40 AM
alfee
Nov 28, 2005 09:37 AM
87ludemasta
Dec 30, 2004 11:58 PM
rafiq7
Nov 2, 2004 11:41 AM
