PLEASE HELP TURBO BUGGIN OUT!!
installed turbo kit, car buggin out, boosting 7-10 lbs, blowing out blue & white smoke, need to know where to install waste gage, also instructions on how to connect piggy back computer,
If you put your turbo kit on with no wastegate and no fuel management your motor's already blown. I suggest you search and find out more about turbocharging before you try and boost again. Good Luck
I hate to say search but you should. Though a good place to install the wastegate is before the turbo lol j/k. If your talking about the vaccum lines then install the line to the turbo compressor if not then the some where on the intake manifold where there is not interference. A lot of people recomend at the brake booster. Therea are a lot of piggy backs. If its a Apexi one then they have the documentation right on their website. Blue & white smoke arent good. Though when its cold white smoke can happen no matter what. Generaly on a turbo car the only smoke you should see is black.
civicturbo22
Jun 8, 2005 09:54 AM
