heater bypass valve
Old Nov 24, 2006 | 01:21 PM
alex_s817's Avatar
Default heater bypass valve
doea anyone have a picture or a link to a picture of the heater bypass valve on a 92-95 civic hatchback? i have one ready to put on my car, but im not sure how it is supposed to be set-up
Old Nov 24, 2006 | 04:01 PM
alex_s817's Avatar
Default Re: heater bypass valve (alex_s817)
bump for help
Old Nov 24, 2006 | 05:45 PM
alex_s817's Avatar
ttt
Old Nov 24, 2006 | 07:21 PM
alex_s817's Avatar
bump
Old Nov 24, 2006 | 07:25 PM
stealthmode62's Avatar
What the hell is a heater bypass valve? You mean looping the coolant so it doesn't get to the heater core?
Old Nov 24, 2006 | 08:10 PM
alex_s817's Avatar
Default Re: heater bypass valve (stealthmode62)
i guess lol
Old Nov 24, 2006 | 08:13 PM
Maybe we should start from the beginning and find out why you don't want a heater in your car.
Old Nov 24, 2006 | 08:19 PM
alex_s817's Avatar
its the exact opposite, i have to install this bypass valve. my car didnt come with one and all i need for the heater to work is this part. i really would like to have heat as it is getting very cold in utah right now. i have the bypass valve which i picked up from a local junk yard, and i have the hoses, all i need to know is which hose it runs off of (left or right side), and if it matters how i mount it. thanks
Old Nov 25, 2006 | 07:03 AM
The only other thing I can think of is that you have a thermostat in your hands. If you took one off at the junkyard, it shouldn't be so bad re-installing it.
Old Nov 25, 2006 | 07:42 AM
alex_s817's Avatar
no, its not the thermostat. but it is inline between the thermostat and the firewall. there are two hoses coming out of the firewall, i believe this bypass valve runs on the hose on the left, inbetween the firewall and the thermostat. i just need someone to confirm this, i just forget how it came off at the junkyard.
thanks for the help
thewrai6th
Mar 10, 2016 04:24 PM
Shaw14
Dec 21, 2009 12:30 PM
AtoZ
Jan 12, 2009 02:37 PM
alex_s817
Nov 12, 2006 06:21 PM
fire7882
Nov 18, 2002 06:16 PM
