engine code problems!!!!
Old Nov 23, 2006 | 07:51 PM
REDREXMANB16's Avatar
Default engine code problems!!!!
i check my ecu for codes today and got code 7 and then code 6 which is the TPS sensor and some coolent thing! I was woundering were i should start cuz i changed out the TPS and it still shows the code and the coolent thing i have no idea were to even start with it! I am very bad with this **** so if u can help in anyway that would be great!! Its obd0 if that matters at all. the car runs fine! it seems to not be to hot or cold or anything just smells really rich after i get on it! idk computer ****!
Old Nov 23, 2006 | 08:39 PM
civicstar's Avatar
Default Re: engine code problems!!!! (REDREXMANB16)
did you reset the ecu and then checked the codes agian to see if they went away?
Old Nov 23, 2006 | 09:54 PM
igotthaspirit's Avatar
Code 6 is ECT (Engine Coolant Temp) sensor. Check your connection at the sensor and then check continuity between the sensor and the ecu pinout. You might do the same thing with the TPS sensor.
msinsky14
Jan 6, 2009 07:44 PM
THE94GSR
Jun 25, 2004 05:07 AM
CIVILGSR
Jul 20, 2003 10:42 PM
White Lightnin
Jun 28, 2002 09:15 AM
.brad
Feb 26, 2002 03:30 AM
