Help! Can't figure it out!
Old Nov 22, 2006 | 10:19 PM
BoostdRex's Avatar
Default Help! Can't figure it out!
Scenerio:
1999 Acura Integra LS. Automatic Tranny. All Stock under the hood.
Stock ECU.
Problem:
Fails to start up smoothly, coughs as if "choked" like a carbureted vehicle, exhaust smokes as if far too rich, then leans out and runs smoothly after it warms up. The smoke is certainly fuel, not oil. Then turn it off, wait a few minutes, start it up again, and same thing happens (sometimes even after warmed up), very rich then leans out to a smooth run after a few minutes. Never a CEL.
Always too much fuel at the start, then leans out to what seems to be "normal".
Changed FPR; changed plugs/wire/cap/rotor, nearly all ignition components; checked timing; full fuel systems cleaning (including injectors). Checked IACV...
Any suggestions of what else to do/check next? I am thinking o2 sensor but I figured it would throw a CEL if the o2 sensor was bad? Hmmmm....
Any help/suggestions appreciated!
Old Nov 23, 2006 | 07:38 AM
Sam92Teg's Avatar
Default Re: Help! Can't figure it out! (BoostdRex)
Coil, ignitor, or sticking injector?
Old Nov 23, 2006 | 09:08 PM
BoostdRex's Avatar
Default Re: Help! Can't figure it out! (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">sticking injector? </TD></TR></TABLE>
Ignition's great, but I'm gonna check this out. Thanks!
Does this happen often???
Old Nov 24, 2006 | 07:50 AM
Joey Tribianni's Avatar
injectors if not timing.
Old Nov 24, 2006 | 02:35 PM
JonGP4's Avatar
gonna second this.. happens often if they run cheap nasty gas all the time without ever changing the fuel filter.
Old Nov 24, 2006 | 02:41 PM
Nors's Avatar
If you changed all those parts, and have no CEL, it is defintly a stuck open injector.
Old Nov 24, 2006 | 03:24 PM
gsrman171's Avatar
how is the hose to the FPR?
95civhb
11
Aug 13, 2010 07:03 PM
x91crxsix
May 20, 2008 09:04 AM
Da9Gro
May 14, 2007 02:29 PM
AllMotorDA9
Oct 26, 2004 06:27 AM
BoostedGSRBubble
Mar 24, 2003 08:46 AM
