Wat type of water pump could I use for my B20Vtec
You could use the electric one that Meziere sells. This would function and look pretty damned awesome. Then again, I don't think that this was the answer you were looking for. Sorry!
you could use anyone you want, but it is recommended that you use a vtec one w/22 teeth. i.e. b16/itr/gsr. which ever one you use, you need to use the timing belt to match. so if you use a gsr water pump, you need a gsr timing belt to go with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH-3 »</TD></TR><TR><TD CLASS="quote">you could use anyone you want, but it is recommended that you use a vtec one w/22 teeth. i.e. b16/itr/gsr. which ever one you use, you need to use the timing belt to match. so if you use a gsr water pump, you need a gsr timing belt to go with it. </TD></TR></TABLE>
oh ok thanks alot
oh ok thanks alot
tacchan
18
Nov 5, 2012 07:58 PM
