water pump???
Old Jun 2, 2003 | 06:08 PM
CIVICNONVTEC's Avatar
Default water pump???
could i use a gsr vtec water pump into my 94 ls motor ? because right now my ls
water pump is bad and i need to change it. but i was also thinking of maybe going
lsvtec in the future so if i take care of the water pump situation i probably wont have to worry about it later. well im also not sure what year or part # the gsr vtec water pump i should or could use? so if anyone out there could help me i would
appreciate thanks for your time.
Old Jun 2, 2003 | 06:12 PM
1_bad_EF's Avatar
Default Re: water pump??? (CIVICNONVTEC)
I think you can use a gsr wp if you you use a gsr timing belt. Can anybody back me up on this?? use a 95 gsr and get it from Acura
Old Jun 2, 2003 | 07:23 PM
92SiB18C1's Avatar
Default Re: water pump??? (1_bad_EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1_bad_EF &raquo;</TD></TR><TR><TD CLASS="quote">I think you can use a gsr wp if you you use a gsr timing belt. Can anybody back me up on this?? use a 95 gsr and get it from Acura </TD></TR></TABLE>
I believe you are correct. I've read it somewhere. However, cam gears of LS and GSR are the same? That I don't know.
Del Soouulll
Nov 23, 2006 09:23 AM
alfee
Nov 28, 2005 09:37 AM
I got a honda
Aug 1, 2005 10:42 AM
87ludemasta
Dec 30, 2004 11:58 PM
thaiphob
Oct 31, 2003 05:24 AM
