LS/VTEC timing belt problem? any ideas?
Old Dec 10, 2002 | 06:19 AM
turboex's Avatar
Default LS/VTEC timing belt problem? any ideas?
Ok we have a b20 block, gsr head, and gsr water pump( its the one with the smaller gear on it, not as big as a b16 pump). what timing belt will we need for this setup?
Old Dec 10, 2002 | 06:35 AM
b18bturbo's Avatar
Default Re: LS/VTEC timing belt problem? any ideas? (turboex)
should use a gsr timing belt 220model for the gsr pump the 210model for the b16a its approx 1/2inch shorted for the b16a
[Modified by b18bturbo, 9:35 AM 12/10/2002]
[Modified by b18bturbo, 9:51 AM 12/10/2002]
Old Dec 10, 2002 | 06:39 AM
HotRodTeg's Avatar
Default Re: LS/VTEC timing belt problem? any ideas? (b18bturbo)
The Gsr and B16 water pumps are the same part number. They both have the larger pulley gear on it. If you have a small pulley gear then its an Ls water pump. If you use the gsr water pump then use Gsr timing belt. Lates
Old Dec 10, 2002 | 06:45 AM
simple4012's Avatar
New User
Default Re: LS/VTEC timing belt problem? any ideas? (streetracer)
gsr and b16 belts are not the same. they are different lengths. For an ls/vtec if you use a gsr or Type R timing belt use a 1.8 vtec timing belt. If you use a stock ls timing belt use an ls water pump. Its that simple. A b16 timing belt is to short.
[Modified by simple4012, 3:45 PM 12/10/2002]
Old Dec 10, 2002 | 06:56 AM
HotRodTeg's Avatar
Default Re: LS/VTEC timing belt problem? any ideas? (simple4012)
No I said the B16 water pumps and the B18c water pumps are the same and if you use those one and lsvtec then you use the gsr/type r timing belt. The if you have the water pump with the smaller gear then its and Ls water pump if you use the Ls water pump then you use the ls timing belt . lates
Old Dec 10, 2002 | 07:00 AM
turboex's Avatar
you guys are great thanks for the help. See my problem is i live in a hick town and there telling me there is only one belt and water pump for the integra (all models). And they keep giving me the one with the smaller gear that does not match our acura belt. I have 2 old ones here in both styles its just that there puter does not list it. oh well ill get if figured out, thanks again
Old Dec 10, 2002 | 07:02 AM
simple4012's Avatar
New User
yep i read it wrong at first...my bad...edited for content
young geezer
Jan 21, 2011 07:42 AM
rick_rabies
Apr 1, 2009 12:59 PM
EGhatch87
May 3, 2007 10:07 AM
TheSwift1
Apr 10, 2004 01:46 AM
hatchii
Jun 9, 2003 10:19 PM
