Fog light install
Old Nov 22, 2006 | 11:15 AM
SHG_Mike's Avatar
Default Fog light install
I have a set of PIAA fogs. For the past month Ive had it wired kind of ghetto. So what my question is I need to tap into a power source and a switched source and obviously a ground. How would i go about doing this and which scources/wires should i tap into. Thanks!
Old Nov 22, 2006 | 11:20 AM
BlueIntegraBoy's Avatar
Default Re: Fog light install (Knappster)
Use female connectors and crimp them onto your 12v and switched source wires.
Connect the 12v wire to Option B+. Connect the switched source wire to Option ACC or Option IG2. Ground it to any bolt under the dash.
Old Nov 22, 2006 | 11:53 AM
BauleyCivic's Avatar
Risky Business
Default Re: Fog light install (BlueIntegraBoy)
Switched source comes from the fuse box - as the picture above illustrates - and any ground can be used. Many of the bolts and mounting points under the dash are grounded enough for this.
Enjoy.
wtemale
Nov 18, 2017 05:08 PM
clutch33
May 4, 2004 06:10 PM
clutch33
May 4, 2004 04:55 PM
scrolanky
Audio / Security / Video
Feb 24, 2004 01:54 PM
rafimos
Nov 5, 2002 09:01 PM
